Question about Akai LCT2060 Television
The power adapter cord has a minor cut in it, and the tv will turn on and off, the red light disappears what is the problem?
    Scholar:
  • 90 Answers
Hi there, good thing you detect it earlier. Heres my tips cut that wire and try to solder it. Or if soldering is not possible rewire it by tie it together and coat with electrical tape for safety. It is possible that you have a cold contact on the supply. Hope this helps. Please rate and vote. Good day
Posted on Mar 17, 2011
What to I do if my TV got wet on the power cord but I am getting picture and sound before it cuts off?
If the liquid got into the TV and onto the printed circuit board, there could be damage to the circuit board. The fact that the TV had a reaction to the liquid is not a good thing. If the TV is still wet inside the problem will remain. If you continue to turn the TV on if it is still wet you might cause more damage. I would wait until the liquid is gone or dry and try the TV again. If the TV was in the normal position to watch, the liquid should run off and dry in a few days.
Aug 20, 2015 | Samsung Televison & Video
Lcd tv no turn on an de red stanby lite is off
The lack of the red light indicates that either the TV's power-cord is not connected, or that the wall-outlet is not supplying any power (check your circuit-breaker box), or the power-adapter inside the TV has malfunctioned.
Mar 16, 2014 | Televison & Video
My Wii has a red light when plugged in, and a green one while turned, on, the problem is, nothing is displayed on the tv or heard, also, the disk drive whirrs for a few second after turning on. The tv...
If the light is red, it means WiiConnect24 is turned off. Green means the system is turned on and it's normal for the Wii to whirr a bit when it's initially turned on.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
That said, Nintendo recommends calling them if this doesn't fix your problem. Hope this helps.
Jan 06, 2011 | Nintendo Wii Console
When I plug the power cord in the wall outlet, the red light turns on indicating that power is there. when I press the "power on" button on TV or on the remote, the green light turns on for one...
Right now the standby 5vdc is working but it may have gone into safety shutdown due to failed power supply or shorted circuits in the backlight inverter board. You need to troubleshoot it to narrow down the causes first before buying the wrong parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 01, 2010 | Norcent Technologies LT-2722 27 in. LCD...
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Cannot get power with batteries or adapter.
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Oct 10, 2008 | Vtech V.Smile TV Learning System
TV Picture cuts off.
The blue screen means that you have lost signal. If the set don't have signal for so long it turns itself off. "power saver feature" Check all connections or replace cables, If that don't work the signal board may be going bad.
Feb 26, 2008 | Televison & Video
Akai LCT2060 Television Logo
15 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
