Question about Panasonic Televison & Video
I CANNOT RECORD HD - TV STATIONS ON P/SONIC DMR EX78. GET MESSAGE" CANNOT DECODE HD' PLS REPLY JOHN
  • 1 more comment
  • johnmoore43 Mar 17, 2011
    no codec that I can ascertain.. do you know this particular model panasonic dmr ex 78. as I am Thinking part @ of your ans that it just does not recognise HD stations.. John
  • johnmoore43 Mar 20, 2011
    wanting to know does dvd Panasonic DMR-EX78.. HAVE CAPABILITY TO RECORD hIGH dEFINITION tv FREE TO AIR ??? (HD) MESSAGE ON SCREEN SAYS "UNABLE TO DECODE HD".. LAST ANSWER I RECEIVED STATED CHECK CODECS.. ITS A DVD RECORDER NO A COMPUTER AS SUCH...jOHN
    yes this expert answered "the Question" that i asked.. thank you..John
  • Panasonic Master
  • 5,167 Answers
This DVD recorder only has an SD tuner. Thus it can't interpret HD signals. The only way to record HD content would be to use a set top box with an HD tuner. Connect this to the video input on the front of the unit. (The set top box output will need to be composite video (SD) or S-video.)
The manual for the European model is available here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/DMREX78-_E . You will need to review the Panasonic DMR EX78 or enter a security code.
I hope this helps.
Posted on Mar 20, 2011
  • Cindy Wells Mar 20, 2011
    In the U.S., I know that the basic digital-to-analog OTA tuners could be used for this. (These weren't advertised as HD boxes.)
    You're welcome.
    Genius:
  • 1,622 Answers
How to Record TV Shows to a DVD Disc
things you'll need:
* DVD recorder
* Blank recordable DVDs
* Audio/video cables (composite plus S-Video, component and/or HDMI)
DVD box sets of TV series are a popular item for collectors, giving them a chance to own and view single and combined seasons of their favorite shows whenever they choose. However, the costs of purchasing these box sets can add up, and for those looking for a different way to compile a collection, it is possible to record these shows (and movies and other programs) onto DVD, with a properly
Instructions
Direct Connection
Purchase a DVD recorder with a digital TV tuner, such as the Panasonic DMR-EZ28K. Using a direct connection from the cable outlet to the DVD recorder to the TV will be the method of choice when no cable or satellite receiver box is also in use. By connecting this way, usage will be very similar to how a VCR is used to record shows off TV.
Connect a coaxial cable from the wall outlet to the coaxial input on the rear of the DVD recorder.
Determine which type of cable you wish to use to connect the DVD recorder to the TV, based on the types of inputs available on your TV. This can be either coaxial, composite or S-Video for standard-definition video, or component or HDMI for HDTVs.
Connect the selected cable from that output on the rear of the DVD recorder to the corresponding input on the TV.
Turn the TV and DVD recorder on and use the recorder's remote control to select the channel to be viewed and recorded. Open the tray and insert a blank DVD.
Select the recording mode if your DVD recorder offers that option. Press "Record" when you want recording to begin, and press "Stop" when reaching the end of the program.
Peripheral Connection
Use a peripheral method of connecting the DVD recorder when a cable or satellite set-top box is in use and when you wish to receive optimal HD video when not using the DVD recorder. Start by connecting a component or HDMI cable (or coaxial, for non-HDTVs) from the output of the receiver box to the corresponding input on the TV.
Connect a composite audio/video cable (red and white plugs for audio, yellow for video) from the output on the receiver box to the composite input on the DVD recorder. You may also choose to use S-Video instead of the yellow composite cable if your devices offer this. Connect similar cables (or use component or HDMI cables for higher quality video when viewing DVDs) from the recorder's output to an input on the TV.
Select the channel or program you wish to record using your cable or satellite set-top box (or DVR, when available).
Load a blank DVD into the recorder, set the recording mode and press "Record" when the program you want to record begins, and press "Stop" when finished.
Tips & Warnings
DVD recorders with a TV tuner can also be programmed to record at a selected time, much like a VCR.
Consult the owner's manual of your particular DVD recorder for further operating instructions.
Posted on Mar 17, 2011
  • Panasonic Master
  • 12,061 Answers
Hi, this problem can most likely be sorted out by obtaining and installing HDTV or H.264/MPEG CODECs. OR Whatever the CODEC you need is. To find out, simply discover what the "Format" that the TV station sends it's Pictures in, this can be say, MPEG2 MPEG4 DivX, AAC, H.264
If these CODECs cannot be, selected, used & loaded or upgraded then it may simply not be possible to use it. Not ALL DVR's will decode and record ALL TV transmissions, the receiving/recording device
Also this message will appear if the station trying to be viewed is a pay-per-view, and one doesn't have a subscription etc.
If you could once record, and now it will not, then perhaps try to reset the device back to Factory settings, and then simply trying to reset it all up again.
Now if this doesn't seem to help, then it's possible that there is an internal fault? if this is suspected then the best thing to do, will be to contact a Panasonic local or head office and ask them for a referral to an authorsied service center, when you make contact here, ask first for a "Quote" as to the cost of the repairs, and then you can make an informed decision as to what to do, repair or replace.
Below is about CODECs
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
I have DMEZ 47V DVD recorder/VCR combo and panasonic digital/ HD tv...when I set up to pre record the equipment seems to accept the information ok but when i try to playback all i get is ..."cannot...
The reason for this is simple; the built-in digital tuner does not support HD, only SD. You cannot fix it, at least not economically where the recorder combo is concerned. But you can obtain a separate HD set top box, and connect the outputs of it to the inputs of your combo if you really want to record HD channels. It's crude, but cheaper and easier in the long term, and it doesn't damage your machine.
Feb 17, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Message appears unable to decode HD channels
DMR-EZ47V and EZ48V models do not feature a built in HD digital tuner - it is only SD - hence the reason it cannot decode HD. It is a model/design limitation; not a fault.
Jan 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I cannot get the new digital channels throught my Panasonic DMR-EX87, that have become available of late, (GEM, 7MATE and ABC News24, I am in Australia). I have performed a system update and...
The tuner in this DVD recorder is a DVB-T SD tuner; it will also tune in the analog signals if you have any analog stations in the area. You will need a separate HD tuner (set-top box) to provide the HD content. I'm not sure if you can record from a set-top box with the recorder set to Line In or Input. The only input jacks are the A/V (composite) jacks.
I wish that I had better news.
Dec 03, 2010 | Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
How do you set the time on Panasonic DMR-EX78?
Maybe slightly different on EX78, but on a E55 the time setting is done from the set-up menus.
These are found by pressing the Functions button on the remote control.
There is the option for "automatic" time adjustment. This uses the time data from Teletext if you have the unit connected to a suitable aerial/satelite/cable.
NB. if your unit only has an analogue tuner, i.e. it doesnt have it's own built in Freeview decoder, when the analogue service is withdrawn in the UK auto time update will cease to function.
Hope this helps.
Oct 08, 2009 | Panasonic DMR-E55 DVD Recorder
Copyright Message on Panasonic DMR-ES10-S
certain files are decoded w/ copyright protection not all
Aug 13, 2009 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
394 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
