Question about Seagate (ST625211U-RK) (st625211urk) 2.5 GB Hard Drive
When i plug it in to usb drive blue light flashes only once but it is not shown on my list of devices on my pc and i cant veiw photos on it
    Master:
  • 525 Answers
The power supply on the drive has failed. What you can do is take it out of the enclosure and put it in a new hard drive enclosure. I had the same exact problem one time. I took the drive out of the enclosure and intalled it in my computer tower.
Posted on Mar 17, 2011
"USB device not recognized" error message MacBook Air
The drivers must be up to date and written for your device. If there are no drivers, it will not communicate and thus it may look like it is working and in place, but the linkage is not there.
Mar 17, 2014 | Kingston DTU30G2/32GB 32GB DataTraveler...
What can i do? my jetFlash V85 is unknown
Connect your flash drive to your computer using an available USB port.
If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive.
A question mark icon should be shown to the left of the label.
Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes."
This will scan your PC for any new devices.
Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive.
If this process was successful, your flash drive should now show up under My Computer as a storage disk.
If its listed as an unknown device
Then right click on your flash drive select rename
Hope this helps
Nov 08, 2012 | Electronics - Others
How do I download photos from my Droid to my toshiba laptop
There are many ways to transfer files (including photos) from your Droid to your Computer. Here is a simple way:
1. Connect your phone to your laptop using the phone's USB cable. Once the connection is made, wait a few seconds for the phone to give you notification saying "USB Connected" at the top bar (aka Notification bar).
2. Tap and drag the bar down to show what's in the notification area.
3. Now tap "USB Connected" in order to select "Mount as Mass Storage Device" or "Turn On USB Storage" or any item meaning the same thing (to treat the droid as a storage device like a flash drive).
4. Once that is done, you should now see a new listing in "My Computer" on your laptop- this is your phone as a flash drive- move/copy/delete your photos and files as you would with any other flash drive.
Sep 09, 2011 | Samsung SGH-X660 Cellular Phone
How will i transfer photos from my pc to my usb?
1. Make sure your photo is on the computer. You can download the photo or access it form the drives or camera.
2. Make sure the USB is plugged in.
3. Once the USB is functional ( if the light on the usb device glows) you can right click any file or folder on your computer and use the option send to <USB device Name> and the stuuf you want will be copied to the USB device.
4. Safely remove the device if your task is done.
Oct 27, 2010 | Computers & Internet
When I connect my pandrive to computer. A massage is shown that the device is not recognized by computer. Window XP 2003 is installed Please send me solution for this problem.
hi
Using the flash drive as the example, you would:
  1. Plug in your flash drive, then go to Control Panel, System, Device Manager.
  2. YOu should find the flash drive listed under USB Devices.
  3. Without taking the flash drive out of your computer, use the Device Manager function to "Remove" the drive from Windows.
  4. When that is finished, take the flash drive out of your computer.
  5. Reboot.
  6. Now, plug in the flash drive and Windows should recognize it again.
  7. If you originally had to load drivers from a manufacturer's CD for the flash drive, you'll have to load them again. You might have to do that if you're runing Win98 or WinMe or Win2000.
Aug 07, 2010 | Computers & Internet
SanDisk Cruzer 4GB Micro - not recognized by computer
Well I have the same problem as Mark. I once couldnt eject my PC properly from my office PC & after that my SanDisk Cruzer micro 2GB pen drive is not recognised in any other PC. But I have tried other USB's they open & work perfectly. And I cant again insert my USB in my od\ffice PC cause they have blocked all the USB's... :(
Please help me urgently... I really need to uyse my pen drive urgently....
Jul 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Exterior hard drive not recognise by the computer
The device used to interface the hard drive to the computer must be compatible with the USB port in the computer. (If our machine has only USB 1 ports but the device needs USB 2 or 3 then it won't function). If the ports are correct, connect up the drive to the computer and then power off the computer and power it back on. Older BIOS's will find the drive during startup and you will then see it as one of your devices.
Apr 02, 2017 | Toshiba Computers & Internet
USB problem with Dell Dim. 4600
1.have you use other usb device also same ?????? try plug in rear port usb also same????
2.try to use you original dell cd to preloaded OS. to see usb can recognizing.if still can't may be you usb port faulty need to change motherborad
Jan 02, 2009 | Dell Dimension 4600 PC Desktop
Imation Swivel Flash Drive Cant detect
is it several times that youve used your flash driver at your office? and which side of the usb port did you plug it? coz when it is your first time to use your flash drive at your office and your plugging it at the front side of the PC. well there might be something wrong with connection and may cause damage to the board of the flash drive. if it your using it several times, well try to check at your PC, then do the following specs:
my computer (right click and select manage)
and under manage window ( select disk management )
try to see if your flash drive registered (you can see the drives of your PC) and see if theres a volume (either raw/ or theres a partition on it).
if not, well the board of your flash drive might be damaged, mostly these were caused by the power of the system, fluctuation is one of them, then improper plugging of the flashdrive.
Mar 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Seagate (ST625211U-RK) (st625211urk) 2.5 GB Hard Drive Logo
79 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
