Question about Supra 1987 87
I have a 1987 toyota supra with turbo . I just replaced the stock 48mm turbo with a 61mm turbo from cx racing the waste gate on the stock one was broke. with the new turbo it wont spool up past 3 pounds of boost ive replaced all turbo hoses and had the intercooler cleaned out and pressuer tested. So i thought the electronic boost pressure gauge was incorrect i bought a autometer boost and vaccum gauge and they both read the same.check engine light isnt on but does work if i unplug any sensor under hood for the life of me i cant figure out whats wrong with the turbo system
    Top Expert:
  • Supra Master
  • 49,327 Answers
A turbo works from expanding exhaust gasses
on the smaller turbo the gasses fill the snail and turbine wheel exactly
That is the engineered design for that size engine
however with the bigger turbo there is not an increases in exhaust gasses to actively drive the turbine so it has been a wasted exercise
with turbos , bigger doesn't equal better as it has to be in relation to the gas flow from the exhaust
again if you haven't reset the ECM for the extra fuel needed for the bigger turbo and inlet flow then there is not the hot exhaust gasses needed to drive the turbine wheel to create the extra boost
Posted on Apr 24, 2017
I am looking for the BEST (fastest) supra ever made STOCK. preferably twin turbo, 6 speed. What is the supra thats stock that will absolutely destroy anything?
A stock anything will not be the fastest thing around. I've seen some pretty wicked 1100+ supras though. Your answer in part would be the 98 tt supra it will run a quarter mile in about 13.3 seconds
Feb 05, 2011 | Toyota Supra Cars & Trucks
What would be the best thing to do to my non turbo 1987 toyota supra to make it faster
Best bang for the buck is going to be airflow. As in cold air intake and exhaust upgrade.
Feb 07, 2010 | 1987 Toyota Supra
Where are fuse located for air conditioning in a toyota supra 1989 ma70
for the air conditioner compressor, or the blower motor in the car? I have info on these cars as they are the only race cars that I build, and drive, currently have my own personal 89 7mgte with stock turbo.
Feb 02, 2010 | 1989 Toyota Supra
How do i install a t70 turbo to a 1987 toyota supra turbo 7mgte 3.0
you will need an additional turbo manifold. I have the correct one its for sale right now on eaby. The ct26 turbo manifold does not allow for proper mounting. I can include directions with the manifold
Dec 03, 2009 | 1987 Toyota Supra
I need of a turbo waste gate on a 7.3 liter
Yes it will hurt the performance if yo do anything wire the waste gate shut. however the waste gate is on the inside of the turbo unless you have a special turbo that is not stock.
Sep 30, 2009 | 1997 Ford F250 SuperCab
Timing Dpecs for Toyota Supra 87 6 cylinder
1987 non-turbo: 10 deg Before Top Dead Center (BTDC) @700 rpm
1987 Turbo: 10 deg BTDC @650 rpm.
To set the timing, you will need to connect a jumper wire between terminals E1 and TE1 on the diagnostic terminal. This diagnostic terminal is located just aft of the engine compartment fuse box. It is a black plastic box marked "diagnostic" on the cover, which flips open to reveal the terminals inside. There is a diagram on the inside of the cover which explains the terminal positions. On the Turbo model, you need to remove the forward section of the engine cover to gain access to the number one spark plug wire.
Jul 25, 2009 | 1987 Toyota Supra
Engine compatible
Yes. However it is a very expensive swap $5000 to $8000 to do it right. You will need the 1J or 2J engine, transmission, wiring harness, ecu, and alot of other pieces to do the swap. The engine brackets will need to be modified and you will have to upgrade your brakes. This kind of swap requires a good knowledge of the Toyota Supra and the engines. I do not recommend this swap for a beginner. A cheaper way is to take a 7M-GTE and upgrade the internals and turbo.
Jul 09, 2009 | 1987 Toyota Supra
Aftermarket exhaust
im not sure where you are located. but here us repair shops with exhaust benders can make your racing exaust system. and most of the time we can install it for you cheeper than youcan buy a cat back system. just stop by an independent repair shop with an exhaust bender and talk to them you will be suprised.
later paul
Feb 10, 2009 | 1989 Toyota Supra
Supra 1987 87 Logo
27 people viewed this question
Top Supra Car Audio & Video Experts
xxxxxx xxx
Are you a Supra Car Audio and Video Expert? Answer questions, earn points and help others
