Question about Compaq Presario 700 470024-192 Notebook
Can a compaq presario f700 handle one 2 gb ram chip
    Novelist:
  • 107 Answers
Simply put, no. It can handle 2 gigs TOTAL but not a single 2 gig chip in one slot.
Posted on Mar 17, 2011
Increase virtual memory
no proberly not,you should never do so.
i understand you wan't to add moore memory (RAM)
windows 32x can only handle max 4 GB.windows 64x 8-12 GB.
invest in some new memory (RAM) that's best.
Apr 24, 2013 | HP Presario Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
How to install a exterior monitor on a presario F700
1plug in monitor 2.right click desktop go to properties (on XP) or screen resolution (on 7 or vista) you should see two boxes labeled one and 2 double click 2 that's you monitor...on xp in the properties window go to settings tab to find that option, if it does not show up reset your computer with external monitor plugged in and repeat process if necessary if that doesn't work you need to update driver for your graphics card/chip
Apr 09, 2011 | HP Compaq Presario F500 F700 and G6000...
I need to change my bios chip for compaq presario f700 but i can't fin it in the mother board does some one knows where is it ? in the main board? exact place please
Changing the bios chips on that particular logic board requires soldering. It's a black chip with white writing on it, it's flat, and it has about 20 prongs on it.
Mar 22, 2011 | HP Compaq Presario F500 F700 and G6000...
Can i put a 2 gb ram upgrade in my compaq presario cq-60 along with the existing 1 gb ram that the computer came with
probably not ... traditional wisdom says memory chips should match for best results and I think there is only two slots ...
if you are physically able to do this ... same number of chips as slots ... take out the old ... put in the new and try it ... then turn it off again ... put in the old ... the worst thing that will happen is your computer will not boot.
Aug 12, 2010 | HP Compaq Presario CQ60Z Notebook
How difficult is it to install memory chip ugrade,,,
No problem in replacing the RAM chip modules, just make sure you ground yourself so you don't have any static electrical charge when you handle the memory modules.
Just power off the laptop before you remove and replace the RAM.
You won't lse anything as the info. is stored on the hard disk..
Jan 11, 2009 | Compaq Presario Notebook
Where is My Ram Located
I got new Ram Chips and need to install them Where are they located ? its a Compaq Presario 750 TU,WHAT IS YOU PRICE LIST?
Dec 11, 2008 | Compaq Presario 700 470024-192 Notebook
RAM
your laptop has:
PCs built for Windows XP normally can handle 1 GB to 2 GB of memory.
PCs built for Windows Vista normally can handle 2 GB to 4 GB of memory.
This is what you need and the pricing is there too.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=20209&mfr=HP%2FCompaq&model=Presario+Notebook+V2000+Series+%28CTO%29&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=20209-HP%2FCompaq-Presario+Notebook+V2000+Series+%28CTO%29&distributor=0&submit1=Search
Here is the service manual
http://h10032.www1.hp.com/ctg/Manual/c00568473.pdf
Let me know how you make out.
Dec 07, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
