Question about Ignition System for Isuzu Pickup
95 isuzu pickup, no spark, no fuel, cranks but doesn't fire...
    Novelist:
    Habit-Forming:
  • 98 Answers
Check the ecu fuse isn't blown
Posted on Sep 19, 2014
95 Isuzu p/u fuel pump runs with key in the start position, but fuel pump does not run with key in the on position
The fuel pump only runs when the engine is being cranked or of course is running, it is shut off after about 1 second in the run only position.
Feb 09, 2017 | Isuzu Cars & Trucks
1996 Isuzu Rodeo won't crank is getting fire to the coil but not from the coil sometimes. It will run and then die
If it wont crank. Check your battery make sure it has voltage to start vehicle and check also when cranking and while running. Inspect spark plugs and coil wires for any exposed wires. Makes sure spark plug gaps are within spec. If everything is ok check fuel pressure with pressure gauge could be filter or pump and or regulator if fuel pressure fails. But most likely be your distributor
Jan 04, 2016 | Isuzu Cars & Trucks
I have a 93Isuzu pickup I am getting no fire to sparkling any one know y
spark is controlled by cam/crank position sensors, immobiliser and ignition module.
Mar 17, 2015 | 1993 Isuzu Pickup
My chevy s10 pickup 2.2l sputters amd backfires even blew out muffler i have tried everything i can think of whats wrong
The timing chain and gears are probably worn causing late valve timing. This will cause backfires, and flames out the intake. I'm guessing this is a high mileage engine.
Jan 22, 2014 | Metra Chevy S10 t10 Pickup, Gmc Sonoma...
Engine cranks and tries to start but wont
I would first pour some gas in intake if it fires or runs a little could be fuel filter or fuel pump.if it don't fire pull a plug out and crank see if theres spark that's where id start
Oct 09, 2013 | 1992 Isuzu Trooper
A isuzu rodeo crank but no start
first check fuel pressure. then check for ignition fire to spark plugs. the check for injector pulse. see which one is not available then post your results.
May 23, 2012 | 1994 Isuzu Rodeo
Hi my 1999 s-10 cranks over but wont fire up...
Check to see if it has fuel by spraying throttlebody cleaner into the throttle body and then trying to start it. If it fires up for a few seconds then shuts off its the fuel pump or restricted fuel filter. if it does not fire up then you need to check spark. if your getting a real weak or intermittant spark or even no spark at all its probably the crank position sensor. Sometimes the coils go out but not very often.
Sep 14, 2011 | 1999 Chevrolet S-10 Pickup
My 1981 isuzu pup Diesel won't statrt it was running fine but one day did not start,,,, checked if spark plugs had electricity and it has/ don't know what to check or do to start it back on
??diesel with spark plugs??? check you ate getting fuel desels don't have spark pluge the fire of compresion they might have glow plugs but I think if it is a gas engen with spark plugs and you put disel in it there is your problem
Oct 24, 2010 | 1986 Isuzu Pickup
Isuzu Hombre 4.3 (Chevy S10) 1997 won't start
Definitely check for spark next. let me know what you find.
Dec 30, 2008 | 1997 Chevrolet S-10 Pickup
Ignition System for Isuzu Pickup Logo
293 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
George Agios
George Agios
SriPhi
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
