Question about Cameras
There's a circle around the flash symbol so the flash bulb won't go off when you take a picture, well I haven't used the camera for a while and I've forgotten hou to remove the circle so as to use the camera inside so the flash will flash.?
    President:
  • 1,901 Answers
You have the flash disabled.
What make and model is the camera. You do not give that information in the post.
Thanks,
Wayne
Posted on Mar 17, 2011
Some time internal flash does not work in my nikon D3100 camera
When in program and manual mode, you will have to set it to flash. Make sure the circle around the electric bolt on the screen does not have a line through it, and it should work. There is usually a button with the symbol on it somewhere around the lcd(I'm not very familiar with your model or I'd tell you where) or it may be in the on screen menus if it's not a button around the screen.
Mar 15, 2012 | Nikon D3100 Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
How do i get the flash to work
Ascertain that the camera has an alternate buton to activate the flash. In situaiton that camera has an automatic flash would take effect whenever envrionmental conditions either lightening requirements were observable. refer to the cameras user guide to familirise with feature functiosn.
Mar 02, 2011 | Vivitar V5024 Digital Camera
My flash doesn't work. It pops up and the lightning bolt symbol appears in the shooting info, but it doesn't fire and the camera takes a long-exposure picture. I don't think it's the plastic collar...
i`m afraid the flash-bulb is broken, you still can use external flash such as SB 600, SB 800 or SB 900
another option is using tripod while taking pictures without flash, but you have to be patient and not recommend for moving objects
hope this advice help you with your problem
Dec 18, 2010 | Nikon D60 Digital Camera
How to turn the flash on
On the back of the camera, push the right arrow and you will bring up the flash options. Most of the time you might want to choose "Auto", but the lighting symbol without the circle around it will be the flash "on" setting. If the flash doesn't work in this setting, something else is wrong, possibly the Xenon tube is bad or the flash capacitor inside the camera. Hope this helps.
Apr 11, 2010 | Olympus Stylus 710 Digital Camera
Camera fails to flash every time we take a picture
1.Turn off the camera.
2.Install a set of new or fully charged batteries into the camera. then turn it ON
3.Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash. a86196b.jpg
4.Take a picture. [If flash still doesn't work contact Kodak support line 1 800 235 6325 (23KODAK)]
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
How do I turn off the flash for a coolpix 885?
There is a dedicated button (with the symbol of a lightning) for the flash. To turn off flash, press the button (maybe repeatedly) till the flash indicator on screen shows 'lightning with a circle around it'. To set it back, press the same button till the display shows Lightning and A.
Search on the Internet, you will definitely find a soft copy of the User Manual of your camera.
Jun 22, 2009 | Nikon Coolpix 885 Digital Camera
Hello i want to turn the auto flash off
Press the up arrow on the back of the camera - that seems to be the flash mode setting - select which flash mode you want - you have to hit the down arrow once to see the flash off option which is a picture of a flash symbol in a circle. Then press ok. The flash should now not fire.
Dec 10, 2008 | Olympus i:robe IR-300 Digital Camera
Fill-In
press button with the downward facing arrow ,lightning looking symbol..when flash is on you will see that same symbol on screen.when it is off ,you will see that symbol with a circle around it ..
Nov 16, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Open Questions:
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
