Question about Linksys E3000 Wireless Router
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop, "at 100mdps"the laptops are only running at 75mbps is there anyway to configure eitheer of any of the above to make our laptops run internet faster than 75
Hi try here http://www.scanmyspeed.com/
to check your internet speed test..
Posted on Apr 28, 2011
    Problem Solver:
  • 7 Answers
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to www.speedtest.net and click on one of the links on the map. This will tell you how many mbps you get to the internet.
Posted on Mar 17, 2011
Went from wildblue internet service to dsl and need to know how reconfigure linksey router
Wildblue is DSL Internet service provider.
You can change the Internet connection settings of Linksys E3000 manually.
Or you can simply reset the router and reconfigure it by running the CD.
See How to setup Linksys E3000
Oct 17, 2011 | Linksys E3000 Wireless Router
Trying to set up e3000 router on iMac lion and keep getting window saying unsupported os need mac os x 10.6.1 or later. I have 10.7
Try to setup router manually.
You don't need to run the CD.
Open the setup page of the router and change the settings manually.
See How to setup Linksys E3000 router.
Aug 16, 2011 | Linksys E3000 Wireless Router
How to connect the E3000 on a ADSL Line ???
Thank you for using FixYa
Wireless connections have a lot in common so here is a link that will give you the general configurations for a wireless Router to PC. Keep in mind that you will need to configure both the computer and the router in two separate steps. That is why it is best to use the setup disk that normally comes with a new piece of equipment and the cables.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Also keep in mind that the equipment should be matched or designed to work with the other equipment. You will have some kind of a modem either a cable modem or internal modem or external modem that the router will have to connect to.
It is best to allow your own Internet Service Provider to set up the connections. They may not be able to support the configuration if you do not purchase it from them and then you will need to do-it-yourself.
Here are the links for configuring the computer with the different operating systems
Win XP http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Win Vista
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Win7
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this was useful and please comment if this was helpful to you.
Mar 23, 2011 | Linksys E3000 Wireless Router
How do you connect 2 routers into one network? I have a Linksys E3000 and a WRT110...I've had the wrt110 for over a year but I found I needed a second router to cover my entire house so I purchased a...
The easiest way is to run a long Ethernet cable from one of the 'LAN' (or 'network') ports on the "first" router to the 'WAN' (or 'Internet') port on the second router. The "first" router is the one connected to your cable-modem or DSL-modem. Both routers will auto-configure themselves for this "wired" connection. Configure the wireless-adapter in the second router as per normal.
Or, run a long Ethernet cable from the cable-modem (or DSL-modem) to a location in the "center" of your home, where you can put your wireless-router, such that its signal spans the entire building.
Or, move the cable-modem (or DSL-modem) to a location in the "center" of your home, and connect the one router at that location.
Dec 15, 2010 | Linksys E3000 Wireless Router
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Router will not route to another router of same type
The hughes modem is not a router.
What are you trying to do? Install the Linksys?
Plug the ethernet port on the Hugnes to the "Internet" or "WAN" port of the Linksys.
Then if you go into the config of the Linksys, you can tell if it gets a public IP address.
May 21, 2009 | Linksys Computers & Internet
Does a satellite internet network require a special wireless router or will a DSL wireless router work? (Huges satellite)
They will provide you connection on their satallite modem. You can use any wireless router of your choice with the same.
Regards
Sammy
Aug 27, 2008 | Computers & Internet
Linksys E3000 Wireless Router Logo
387 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
