Sparking and flashing at the bottom and keeps blowing fuse
    President:
  • 1,654 Answers
Pleas unplug this and call a service teburn your house down. Sounds like a pump motor has shorted out or the wiring harnes has come off and you have bare wires touching metal. Once unplugge you can take the cabinet off and look for the bad spot, should be burnt!
Posted on Mar 17, 2011
Frigidaire microwave FFmv164lsa keeps blowing fuse
Disconnect connections at primary of the power transformer and try with a good fuse. If the fuse blows again, check crowbar microswitch in the latch assembly.
Dec 23, 2017 | Frigidaire Microwave Ovens
My kawasaki f580v lawn tractor keeps blowing fuse to regulator ?
look for short in wiring anywhere near motor or exhaust
Jul 09, 2014 | Garden
2004 Mercury Mountaineer Radio Fuse Keeps Blowing
That circuit F-2,may be shared with the cigarette lighter and it may be causing this,disconnect lighter wire and see if fuse still blows.
May 29, 2013 | Mercury Mountaineer Cars & Trucks
99 vw jettal 2.0 gas fuse 29 15amp fuse keeps blowing-no spark unpluged coil and fuse keeps blowing. help please
Thats the fuse for the ECU, engine control module, and is a 15amp for gas 2.0. i would locate the ECU which is under the center of the plenum in the engine compartment and disconnect the long plug. Check for green discoloration on the multipin connector. Sometimes moisture will get in there and short some of the pins together. Leave ECU unplugged and replace the fuse. If it still blows cause is between the fuse and the ECU.
Dec 27, 2010 | 1999 Volkswagen Jetta
Carnival 2005 model keeps blowing a fuse on the inner panel( 3rd from bottom) and has done so repeatedly since back brake light replaced. Immobilizes until fuse is replaced. Driving when spark flashed and...
May be i light socket shorting out if you can not identfy the fuse you may want to invest in a haynes manual you can pick this up at any auto parts store they are only like fiftteen dollars and are a must have they are full with all the information you will need.
Nov 14, 2010 | Kia Sedona Cars & Trucks
Getting a message
Have this checked with another scan tool. Link error is produced when the PCM fails to respond to the scan tool. More times than not this is the PCM failing.
Jan 23, 2010 | 2004 Ford F150
05 altima blows fuse for left headlight
Go out at night, or dusk, with a flash lite, replace the fuse with a higher amp or any spare fuse, turn out the lights, turn on the car lights, look for a spark somewhere, have people standing around engine comp, if it doesn't blow, wiggle wires, if it shorts out, you should see a spark, fix with tape, you should be all set.
Dec 29, 2009 | 2003 Nissan Altima
Ikeep blowing the ecm fuse as soon as i turn on the ignition and when i hoo up the positve cable to the battery i get a big spark
CHECK FOR IGNITION WIRES SHORT TO GROUND.I HAVE SEEN A BAD FUEL PUMP BLOW ECM FUSE.REMOVE THE FUEL PUMP FUSE DISABLE FUEL PUMP AND SEE IF FUSE KEEP BLOWING.
Sep 01, 2009 | 1994 Chevrolet Cavalier
70a fuse in main box keeps blowing
dead short in wiring, maybe or fan moter is stuck or will not turn causing fuse to blow? can you smell wiring getting hot> or brushes shorting in fan moter.
Jun 25, 2008 | 1989 Honda Accord 4 Door
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
