Question about Honda Karcher G2400HH-R Pressure Washer
Wont start got spark cleaned carb used start fluid wont turnover
    Sergeant:
    Champion:
  • 250 Answers
I would take a compression test on the engine It should be over 85 psi.
Posted on Mar 17, 2011
Lawn mower wont start
clean out carb.
Mar 14, 2015 | Garden
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
I've got a ryobi rotary hoe on a garage sale can't
Use carb fluid to see if it will pop off for a bit. If it will then you have fuel issues, i.e., carb adjustment, fuel lines, or rebuild carb.
Aug 31, 2014 | Garden
I got a 1994 suzuki katana gsx 750 from my brother the bike has been sitting for a couple of years. it started when i got it but it only ran for a minute so i geuss it burned whatever was in the carbs. i...
you say you cleaned the carbs, but did you pull and clean the jets ? they are very very tiny holes, and take like nothing to plug them. pull the jets and run a wire from a wire brush thru them, should start for you now
Mar 12, 2011 | 1994 Suzuki GSX-R 750 WR
I have a 1990 yamaha 100 cc 4 wheeler and we replaced the spark plug and cleaned out the carb and its turning over but wont start. I know the spark is fine but it just wont turn over, any ideas? maybe...
If the spark is fine, then it is not wiring. It is going to more than likely be fuel. Try spraying a little starting fluid in the air filter. If it starts, then you will know that it is fuel. Make sure that the carb is getting fuel from the tank. A lot of times the filter in the tank will get plugged up. If the bike doesn't start with starting fluid, then the problem is not fuel and will have to be either the timing is off or not enough spark. The spark should be blueish purple.
If this helps you please rate by checking the 4 thumbs up! Thanks for using Fixya.com
Jan 12, 2011 | Yamaha G5 Motorcycles
26 hp briggs it is firing and full of fresh gas but wont start.
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Jul 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
I have a 98 honda foutrax 300 4 wheeler it started acting up and now it wont start took the carb. off and cleaned the jets and everything up and pulled the spark plug out and put my fire over the hole and...
remove all of the old fuel using a siphon bulb and hose. Put in brand new fuel and make sure the line from the tank to the carb. is flowing gas. if not clean or replace the fuel line
Jun 17, 2009 | Honda NS 250 R Motorcycles
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
Honda Karcher G2400HH-R Pressure Washer Logo
186 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
