Question about Dryers
My dryer kenmore model 110.C66492500 stop heating and at the same time will not stop unless i turn the timer off. I check the two prong on the porcelain on the heating block and theres 240 volts there could someone help me thank you
SOURCE: Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Posted on Oct 29, 2008
  • 1028 Answers
SOURCE: WHIRLPOOL DRYER GOLD GEQ9800PW1 HOW TO MAKE IT WORK WITH 220 VOLT
ck frequency on tag if US will be 60 cycles ..most overseas areas are 50 cycles ..not gonna work without some sort of converter
Posted on Nov 18, 2008
beltronic205
  • 1456 Answers
SOURCE: My Brand new GE model DBXR463 does not start.
If this is brand new i assume you will have warranty..First of all try the plug fuse, next make sure the voltage setting is correct for your area, I note what you say on this!..to check a timer properly you would need a diagram and multimeter,I wish you well good luck
Posted on Oct 02, 2009
SOURCE: Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Posted on Jan 11, 2010
  • 101 Answers
SOURCE: hello, my kenmore dryer just stop working, light
Is the door completely shut? Did it stop working right in the middle of a cycle? Are you drying shoes in this load? I'd turn it off, and try it again. If this doesn't work, try it on another drying cycle. If this doesn't work, feel free to contact me again. I hope this works for you. Good Luck! Jim
Posted on Mar 30, 2010
Kenmore dryer model #110 C66492500 It won't shut off when we open the door in the middle of a cycle.
Either the switch that senses the door being open or closed is broken, shorted or out of it's mount, or the relay that it controls has burned or stuck contacts!
Apr 22, 2017 | Kenmore Dryers
My kenmore dryer model#110.61202013 wont heat up
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating
Feb 22, 2015 | Kenmore Dryers
Kenmore model 110.69422801 Good voltage all components ohm out ok, spins but no heat. can the timer on this model cause this?
GOD IS STILL GOOD !!!!
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 23, 2014 | Dryers
What is wrong with my gas dryer ? no heat and wn't shut off.
FIRST OFF IN THE AUTO DRY MODE THE DRYER USES THE MOISTER SENSOR AND AS LONG AS THE MOISTER SENSOR DOES NOT DETECT HEAT OR DRIED CLOTHES IT WILL CONTINUE TO RUN FOREVER.
NEXT AS FOR UR NO HEAT:
Aug 09, 2014 | Kenmore Dryers
My kenmore dryer 110.77432600 wont dry clothes
seems like 2 issues here. bad timer? and heating issue? ELECTRIC Dryer no heat or little heat:
Aug 03, 2014 | Kenmore Dryers
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
Jul 04, 2014 | Kenmore 500 6952 Dryer
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Jun 07, 2010 | Dryers
Hello, my kenmore dryer just stop working, light inside is still on but will not turn or come on Mod# 110.c66492500
Mar 30, 2010 | Kenmore Dryers
Dryers Logo
320 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
