Question about Acer AL1715 17 inch LCD Monitor
My AL1716 monitor does not power up on start-up. The green power light flashes, but no action otherwise. However, if left alone for a while it eventually comes to life. Is this a power supply failure, i.e. bad capacitors. Also, the problem manifested itself following a household move. I thought I'd packed it quite well, but it has not worked corrected since being relocated. Do I have an excuse for a new monitor?
    President:
  • 670 Answers
The flashing green light with no display is a good sign that the backlight power supply is failing. Since it comes back on after a while, seems to me to indicate that it's a part that is out of tolerance and as the power supply tries to recover, starts to work. Probally it a capacitor that is going bad. Don't think the move would cause a problem. You could fix it by replacing the capacitors for less than $20. There is seller on ebay that just sells replacement capacitors for LCD monitors if you want to fix yourself, otherwise spring for a new one.
Posted on Mar 17, 2011
  • 11,361 Answers
More likely to have bad caps, look for caps with domed tops, replace them in a set.See my pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1715b/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Hi, My Acer AL1716 monitor has stopped working and the light on it just keeps flashing. I have put a new power cable on it but still the same problem. I have plugged it into another PC and it still is not...
More likely to have capacitors failure in the power supply section, that will be the first place to check, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside when you open it up so we can guide you further.
Mar 26, 2010 | Acer AL1716 17" LCD Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Acer AL1716 A Monitor does not start
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Computers & Internet
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Sony CPD E500 - Power On from cold problem
as u told ur monitor is excellent only... it is in good condition no problem will be there ... may be there is problem with the operating system just try reinstalling it... ur problem will be solved...
Feb 05, 2008 | Sony CPD E500 (White) 21" CRT Monitor
Acer AL1716 Power problem?
i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
Jan 18, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1715 17 inch LCD Monitor Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
