Question about Samsung SyncMaster 932B LCD Monitor
Flicking screen when initially turning on the monitor. It takes approximately 10 minutes of screen flicking before the screen stays on. I constantly click the power button in the bottom right corner on and off and shake the mouse. Please advise what is happening and a solution to stop it. Thanks, Badonna Birdsong
  • 11,361 Answers
It is time to look inside for bad caps with domed tops a shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Samsung%20932B/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 17, 2011
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
My Konica md#7020 copier does not power up to the "touch screen". When I turn on the main power switch the light indicating I am getting power goes on. However when I press the button to turn on...
After the sub power switch is turned on, the Konica name displays for approximately 10 seconds, until initial machine settings are established. Then, the Warm-Up Screen displays for approximately 6 minutes, until the ?xing temperature is reached. The Basic Screen displays after warm-up. Initial settings are shown on the next page. Except for Print Quantity, all initial settings can be changed by the Key Operator.
Jan 06, 2011 | Office Equipment & Supplies
When computer is turned on monitor flicks on and off . i then have to turn it on and off and eventually after about 10 minutes the monitor stays on
This could be more than one issue, but the first I would approach would be the power supply for the monitor. I'm assuming the monitor you're referring to is an LCD with a separate power supply. If the power supply is failing, it would cause this sort of problem. Check your monitor's documentation to see how many volts are required, and then use a multimeter to check the output voltage of your power supply. If it isn't steady, or if it's below spec, you need another power supply.
It could also be the connector cable from the screen to the computer, but if the cable isn't being moved around I would not expect that to be the issue.
Hope that's helpful.
Jan 01, 2011 | AOC Monitor
If computer and samsung 931b monitor have not been used in a couple of hours the screen comes off initially and then shuts back off. I've been resolving this problem by turning the screen off and on...
More likely to be bad caps with bulging top or leaking liquid in the power supply for monitor this age, you need to open it up and inspect the caps first, post back what you see so we can guide you further, see example of faile SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
Samsung SyncMaster 932B LCD Monitor Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
