Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How do I change the madrel on a craftsman Lt 2000 42" 17 hp? The star bolt is worn down
    Brigadier General:
  • 3,911 Answers
Remove the deck from the mower, take off the blade, take off the deck drive belt, take out the bolts which hold the mandrel to the deck. put new mandrel in, reverse the whole order. do yourself a favor and take lots of before pictures so you do not have to ask how to put the belts back on. mandrels can be obtained at small engine and mower repair shops. you may just want to replace all of them while you have it apart as they are all the same age and wear.
Posted on Mar 17, 2011
Change oil
Mine 17. On the right side it has 1/2 " pipe plug. Some have clear hose on it. Some have like pipe tee with a bolt in it. Loose the bolt to drain oil.
Mar 10, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
ACER ASPIRE X3910 EVENT ID 41 KERNEL POWER CRITICAL
If it just stopped and restarted proper is nothing to worry cause it seam just like a memory dumping error or so ..If it asks to choose a boot on start ..just start normally or choose to start with the last known configuration that worked.
If it do not want to start it may be a case of corrupted boot file ..and need to repair the boot configuration using a operation system disk or the recovery partition ..My advice is to reinstall a clean copy if it makes troubles again ..It may have something in the system that cause it ..and reinstalling will remove the settings and programs ..and when you install them again try them one by one ..and you will know which one is not supported..
Nov 21, 2011 | Acer Aspire X3910-U3012 (PTSED02010) PC...
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman LT riding lawnmower and for some reason the one of the blades is a very loud noise. I have tried going under the deck and tighten up the bolt that holds it in place but it still making...
Check for foreign objects caught under the deck, as well as for a bent blade. If that's not the problem, look at the mower deck belt - is it burnt or worn in a spot? Take it off, and see if you can turn the blade spindles and idler pulley freely. If they scrape badly or are frozen in place, that's the problem.
Jun 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt 2000, blade not staying in place
i would need a complete sears model number to look this up for you, however, you will need to remove the intire blade spindle housing, then you can remove just the shaft from the housing. and just replace the shaft. Will save a lt of money.
if you can find the complete model number you can go on the internet to
mtd.com/parts or to ayp.com/parts
and you can pull up a parts diagram and find the exact part number and order it online, or take model number to sears and they will either have it in stock or can order it for you. Sears will however cost you a fair amount more then ordering online. I hope this helps you
May 28, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The stars on the lawn tractor deck that hold the
This is a common problem with most of this era tractors the easist way to fix is pick up new ones either at NAPA auto parts store or TSC Tractor supply both carry new star washers to replace the worn ones, and it as simple as removing the old and replacing with the new. Hope this Helps Don
Nov 09, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 1987 craftsman riding 17 horse mower. I
Sounds like the rings are worn and letting oil escape past them into the cylinder head. After all, it's been in service a long time. There are several options, including a rebuild with boring out the cylinder and put oversize rings in, buying a new engine and replacing the old one, or just buying a new mower.
Sirwriter
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
289 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
