Question about Kenmore Dishwashers
My kenmore m # 66515829 the water jet spinner under the top basket is not spinning to clean the dishes, I have set it in a postion closed the door let it run then open and it is in the same spot. I have taken off the spinner to make sure it is clear of debris , i see some water dripping out of the spinner but don't know if it is from other jets. Any ideas would be great.
  • Kenmore Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Posted on Mar 18, 2011
Bosch silence plus 50dba not washing dishes! using Jet dry, recently cleaned the screen. any other troubleshooting ideas? ThNk you!
Check to make sure the spinner washing parts are loose and spinning. You can turn them by hand. Many times plates are too tall and block the washing arms from spinning. Push all the baskets in and look into machine and spin the arms. If that's not it then it's somehhing rlectronic that's not taking the machine thru the cycles.
Apr 08, 2015 | Bosch Dishwashers
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Dish not realy not clean leves film on them same soap as alwayes
Hi. Check that the arms are spinning. Something maybe jamming arms like a knife or fork sticking below the basket hitting arm or check that the jets, particularly the end jets are not blocked. Easiest way to check if spinning is to rotate arms into a known position and start a cycle with dishes in machine. After say 1 minute open door and see if arms have rotated. Cheers. Slavious
Sep 24, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
The top spinner/cleaner dish sprayer thing isn't spinning or spraying water on to the dishes on the top shelf. The rest of the dishwasher works. Any suggestions on how to fix?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Not getting dishes clean
Hard to believe but you have to clean the dishwasher. There are various screens and baskets down in the bottom of the dishwasher. Take out the rolling bottom dish rack and you will find the first layer of filter there. Usually there is a handle on it lift or turn and lift that whole rig out and wash the basket and all the filters. There even may be a second layer of filter below that. Then check down in the the very bottom for chunks of stuff or even broken glass. Now the spinner. There is a spinning water sprayer that can also get gunk stuck inside it.. I found rice in mine. There should be a click lock or some kind of release tabs on the side of the shaft. remove that sprayer and look closely at the water jets to see if stuff is in there. run some water thru it too make sure the jets are open. lastly.. you must run the dish washer every day. if you leave them there over night you will need a jack hammer to remove the dried food. Some dried food like egg yolk will never come off in a dish washer.
Dec 13, 2009 | Dishwashers
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
98 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
