Question about Mitsubishi WD-62525 62" Rear Projection HDTV
V-chip block passcode - Mitsubishi WD-62525 62" Rear Projection HDTV
    Top Expert:
  • Mitsubishi Master
  • 75,571 Answers
Hello
You must have its original remote control handset to unlock your Mitsubishi tv.
After you set the lock, you must use your pass code
to view a locked program, view the locked TV, view
a locked channel, cancel the lock, or enter the Lock
menus.
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and
QV keys on the TV remote control at the same time. This
process temporarily unlocks the TV.
When entering the Lock menu, this process deletes
your old pass code and prompts you to enter a new
pass code.
• You can either enter a new pass code to open the
Lock menu and make changes or press EXIT to close
the menu.
• If any of the locks are turned on and you exit the
menus when prompted for a new code, the old
code and all lock settings are retained.
• If all locks are turned off and you exit the menus
when prompted for a new code, then the previous
code is erased.
OK.
Posted on Mar 17, 2011
Mitsubishi wd62526 tv has a passcode on it that i dont know ;so is there a way to change it or reset it
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Press HOME to exit the menu.
Bypassing Front Button Lock If you have misplaced the remote control, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds
Aug 25, 2011 | Mitsubishi WD-62526 Projection TV
Tip
Bypass V-Chip Mitsubishi TV
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
on Mar 20, 2010 | Televison & Video
Can you reset toshiba tv bought tv from some one it say all programs block enter password
Hello
If you forget the passcode "press recall four times within 5 seconds from the V-Chip menu.This allow you to proceed to the blocking menu and resets your PIN code. OK.
Apr 27, 2011 | Toshiba 27A30 27" TV
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power is not coming on, and when it does it says LOCKED, I don't have the original remote but I am using an RCA universal remote. How can I get my power back on??
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode.This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested.This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.Press HOME to exit the menu.
Jan 05, 2011 | Hitachi 51G500 51" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
TV control at the same time, when your
password is requested. This process
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
How to change the v chip code to a mitsubishi medallion projection tv 62
Good luck, and let us know how you made out with this TV set.
Need to unlock vchip passcode; factory reset?
v chip block just popped up on screen , and i never set the tv to v chip
Apr 27, 2009 | Samsung Televison & Video
Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
MENU
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
CANCEL ENTER
. Press _ to set the passcode and go to
theV-chip ratings menu.
MENU
4. To exit without entering a passcode, press _ to
HOME
go to the previous menu or _ to return to
television viewing.
IMPORTANT
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
65
Nov 24, 2008 | Mitsubishi VS-55707 TV
V chip codes
LauriJo...
From the back of my Mitsubishi Owners Manual, Appendix A
"Bypassing the V-Chip Lock
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time when your passcode is requested. This process temporarily unlocks the TV.
When entering the V-Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode."
I hope that helps you.
Nov 02, 2008 | Mitsubishi WD-52526 LCD TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
