Question about Sanyo Televison & Video
Sanyo remote control will not aiiow the sanyo tv to go on or off.
  • Sanyo Master
  • 5,161 Answers
Is this the original remote or another remote? There are a few things to check. First try new batteries in the remote. (If it is not the original remote, check that the code hasn't been changed.) Next do the buttons on the TV itself work?
If the TV responds to the buttons on the unit, then use a digital camera to take a picture of the remote (the IR beam side) when someone presses a button. Looking at the picture you should see light from the remote. If you do not see any light, then replace the remote.
If the remote is sending a signal, then the receiver has failed. You may be able to replace this at partstore.com or shopjimmy.com. First try searching on the model. If that fails, open the tv and record the part number. Search for the part itself (since many parts are used for more than one model, it may be listed for another brand).
If the buttons on the tv do not work, then the entire board probably has failed. Again try to find the part.
I hope this helps.
Posted on Mar 17, 2011
I NEED SANYO TV CODES FOR A URC-4021B00 ONEFORALL REMOTE
Jadan, CODES FOR SANYO TV try 0154, 0240 0047, 0104 Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What is the code for Sanyo TV remote control One for All URC 3220
http://www.rockabilly.net/files/manuals/URC-4021.pdf
Welcome to Remote Central Universal Remote Control Reviews More
Codes for Universal Remotes
Aug 24, 2016 | One For All URC-4021 Remote Control
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
SANYO REMOTE MODEL: FXWD - PROGRAMMING MANUAL
The Sanyo FXWD remote was used with the Sanyo DS27930 and DS32424 TV. The manual for the TV is available at manualslib.com. The instructions for the remote are on pages 7 thru 11 of the TV manual.
Mar 28, 2012 | Televison & Video
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
RCA remote codes lost
Codes For Model RCR311B
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
Sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
Jan 03, 2009 | Televison & Video
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Televison & Video Logo
53 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
