Question about Whirlpool Refrigerators
I have a Whirlpool refrigerator model # ET1PHKXPQ00 ser# ER2137141, Type 21TFA, dated 05/2004. It runs fine, but I am getting water in the bottom of the refrigerator all the time now. A friend at work told me it could be a plugged freezer drain hose. I originally thought it was leaking ice cube trays, but after replacing them I'm still getting the water. I do not have an ice maker , just plastic trays. Is it hard to get to the hose to get it cleared out?
  • 146 Answers
  • you need to remove the cover where the fan is mounted and you will see ice build up there is the hole but you may need to use hot water to clear the ice and clear the drain hole water should come out to the back of the refrigerator you need to remve the cover behind to see the drain line make sure to disconnect the unit before you work on it.
Posted on Mar 04, 2015
bobicehouse
  • 1524 Answers
SOURCE: My whirlpool refrigerator 21TFA is leaking water
The drain is clogged. Remove freezer plate and pour a mixture of baking soda and warm water down drain.
Posted on Nov 02, 2010
VOTIT
  • 2071 Answers
SOURCE: Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Posted on Jul 24, 2008
  • 55 Answers
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
  1. Check to see if water is flowing @ the water inlet valve @ the rear of the unit. You can remove it and clean if out-then put it back in service. You can purchase a new valve -- maybe @ home depot.
Posted on Aug 27, 2008
  • 172 Answers
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Why is water leaking into the refrigerator from the freezer?
The defrost drain in the freezer is clogged. The defrost water then overflows and runs down the vent where the cool air enters the fresh food section and makes a puddle on the top shelf. You may defrost the unit over nite or have a tech come check it. If you just defrost it and there is some type of debris in the drain line that will not melt then you will still need a service man. Or if you feel brave, and can be totally careful so you will not get cut remove the back wall of the refrigerator after you unplug it and get some towels and boil some water. Gentle pour the hot water into the area below the evaporator, ( the thingy with all the aluminum fins), You will eventually hear the water emptying into the pan beneath the refrigerator. Once you hear that you can reassembly and resume operations.
Dec 31, 2017 | Whirlpool Refrigerators
Can you guide me where can I find the right part number for Relay overload starter for my Whirlpool Gold Side-by-side fridge.Mod: GD5YHEXLS01 Ser: SP2325250 MFR DATE:06-03 I am not 100% sure if I rea
Go to sears parts direct web site and put in the model number. Found the page with unit parts our the page that list the compressor. It will have the newest part number
Feb 03, 2013 | Refrigerators
Whirlpool refrigerator type 21TFA refrigerator won't cool - air vent in freezer keeps icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water into crisper. Water is freezing in freezer pan. Model 21TFA.
i would say you have a pluged drain tube from the top locted behind the freezer rear panel.
Nov 27, 2010 | Whirlpool Refrigerators
My whirlpool refrigerator 21TFA is leaking water from freezer into fridge. This model does not have an ice maker.
Nov 02, 2010 | Whirlpool Refrigerators
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
