Question about Air Tools & Compressors
I have a air compressor it is a central pneumatic and it will air up sometimes all the way but not all the time and then will not build up till it goes back to 0 pounds of presure
    Top Expert:
  • 12,128 Answers
Bad pressure regulator or regulator out of adjustment /or the contacts are sticking
Posted on Mar 17, 2011
Can I use another Central Pneumatic pump on my 61490 air compressor?
sure harbor freight tools sells new air compressor pumps, just be sure new one matches the R.P.M of the motor or I may damage it if it turns too fast of may not make enough air if it goes to slow , also be aware if belt pulley changes its diameter then pump speed will also change
Dec 05, 2015 | Air Tools & Compressors
Central pnematic compressors, will not build up air
Use soapy water to check for air leaks. Can also check piston ring and valves. Make sure engine is driving the compressor.
May 19, 2013 | central pneumatic 212cc, 9 gal., 135 PSI...
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
Owners manual for central pneumatic 95439
I scanned my manual for the same item. If you still need a copy, let me know.
Jan 04, 2012 | Air Tools & Compressors
I have a central pneumatic compressor 21gal 2hp a couple years old the unit runs but will only pump up to 75psi and keeps running and does not build more pressure.It was building up to 110psi and then it...
Its the pressure regulator, if you discharge the air and can set the regulator to a lower psi, and it pumps
to that psi. you will have to replace that part, make sure to have make, model , serial# of compressor
so that the correct part can be fittted to you compressor. good luck!
Jul 31, 2011 | Air Tools & Compressors
Central Pneumatic 2 hp 8 gal compressor won't build pressure just sounds like leaking all the time where do i start to look for problem
if it is leaking air the check valve is bad.find the airline leaving the air pump follow this line to tank.this line attaches to the check valve which is screwed into tank.make sure no pressure is in tank when removing.
May 18, 2010 | Air Tools & Compressors
How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Apr 10, 2010 | Air Tools & Compressors
Operating instructions for central pneumatic industrial paint spray gun md 91011
My #91011 One Quart is not a gravity feed, it is air compressor fee fed. My problem is the nozzle will not fan out . It only blows a round spray mist. ?
Oct 26, 2009 | RTO Central Pneumatic Gravity Feed Spray...
Air Tools & Compressors Logo
270 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
