Hi i have problem with my xerox dc286 error code 124-315 and sometimes the copier just frozen without the error code. can anyone please help me?
  • 2072 Answers
SOURCE: Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
Posted on May 19, 2008
checkitright
  • 1362 Answers
SOURCE: U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Posted on Oct 06, 2008
vmachlis
  • 7 Answers
SOURCE: Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Posted on Dec 21, 2008
fotomohamed
  • 321 Answers
SOURCE: Xerox 7132 error code 092-310
check out for loose connection
Posted on Jun 18, 2009
randula7
  • 78 Answers
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Posted on Sep 08, 2009
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Help me for error code u4 for xerox 5921
The U4 codes for Xerox machines are for the fuser (heat roller) unit. It's rarely something that you can fix yourself I'm afraid.. Sometimes it pops up from overwork and powering off the machine allows it to cool down but if it keeps coming back you need to get it checked out properly..
Oct 05, 2009 | Xerox Office Equipment & Supplies
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Workcentre c2424 Error Code "37,030.48"
Hi Ian_a_nicol:
error code # 37,030.48 means X-axis motor disconnect. The X-axis motor (second phase) is not drawing the expected power from the power supply. you can do the following to determin if the X-axis motor is bad.
1. Run the X-axis Drive test and if it passes
replace the electronics module, if not see #2.
2. Check the X-axis motor wiring for damage
or replace X-axis motor.
3. Call Xerox to have them come out and run the test and determin if it is the electronics module or the X-axis motor, but is one or the other.
pdouglasss
Oct 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Phaser 8500N Printer Error
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
56 people viewed this question
jasbo
jasbo
