Question about Toro Zero Turn Rider 74366 Lawn Mower Tractor Rider Ztr
Hello I have a toro zero turn rider z4220 I think I bought it new about 2 to 3yrs ago when I was putting it up last winter the left drive would not go forward or reverse then shortly there after the right side stopped. so now this spring I have started working on it. the drive belt is tight and not worn I have a small yard. the pulley going into the top of the drive is turning on both sides but no drive on either side. no oil leaks no damage anywhere it has not been overworked with this little yard. the gearbox is not even dirty. this is very disappointing. on such a new machine could this be a defect with these gearboxes. I am a industrial mechanic by trade but am stumped as to what went wrong. thank you for your help
  • mnlaws Mar 17, 2011
    Thank you woobie dog. the control rods that you use to push it around were in the proper position but they are flimsy and went put in the midway position in-between the push mode and the drive mode that fixed it. evidently this is intended to float if you put it into the drive mode slot as I had it the mower wouldn't move I moved the lever to in-between and that fixed it Thank You
    President:
  • 1,273 Answers
Hello, W/D here.
Look for a transmission disconnect rod, usually at the back of the tractor, about even with the top of the gearbox. If it has been moved to the out position, the transmission will not operate from the seat, but you can push it.
Good luck, --W/D--
Posted on Mar 17, 2011
Testimonial: "this was very helpfull I sat on the mower running and the wheels off the ground and could reach the levers slid the back towards the push mode "
Why won't my rider move and keep running?
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
Jul 21, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Belt diagram
HOPE THIS HELPS.. http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=34870&serialNumber=310000001&modelNumber=74366&searchTerm=9lzIRv+p5zeMaPWIo2YCaldb2KV6U4WnyxmRpPSpeQehTowzmaCEK/baRX71tPfJ&defaultTab=parts
Apr 23, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
I need to find out what the voltage output and the miliamp output is on a toro z4220 mower my battery keeps going dead i have replaced it once already Thank yoy
You should have around 13.1 volts at the battery as the engine runs. If its 12 volts or lower - check or replace the voltage regulator. To check the regulator, stop engine, remove regulator plug, get a ohm meter and put the black lead to any ground,and touch the red lead to all the terminals one by one on the voltage regulator - you should get 3 readings - one lower than the other. If you dont get any readings - the regulator is definitely bad
Don in Baltimore
May 02, 2011 | kawasaki 48'' Toro Com Zero Turn Lawn...
Hello, my Toro 14-38 hxl (model 71193)is not
I have 12-38 hxl, and if my grass is too tall, it will wedge under the cutting deck and lock the blades, and the belt willstart smoking white. With the motor off look under and see if you do not have something stuck (branches or grass).Also, check your sparkplug.
Jun 05, 2009 | Toro Garden
Toro Zero Turn Rider 74366 Lawn Mower Tractor Rider Ztr Logo
657 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
