Question about Refrigerators
Door for a emerson compact refrigerator model cr281b
5 Suggested Answers
  • 50 Answers
SOURCE: Emerson Compact Refrigerator not cold.
Make sure the condenser fan is running, it is located near the compressor and blows across the condensing coils, and make sure the coils are clean. Compressors usually do get pretty hot though. And make sure all you fans are running in the inside
Posted on Aug 21, 2009
Testimonial: "I had to buy another one because the fan is not visible & I had no means of taking the back off. My dad will check the fan at home. Thank you!"
woodchuck789
  • 4059 Answers
SOURCE: We have a compact two door Emerson refrigerator
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Apr 18, 2010
dcramer531
  • 1654 Answers
SOURCE: I need a replacement key
.A replacement key should be easy to get.If its the hex style key,a quarter inch nut driver should work. Have you contacted Emerson?
Posted on Dec 05, 2010
  • 12 Answers
SOURCE: Haier Model HRT02WNC compact refrigerator not cool...
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
Posted on Jan 09, 2011
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
How to remove compressor start relay and overload protector cover from an Emerson CR519BE2 compact Refrigerator
they usually just snap out or there may be a ***** to remove it should be visible
Mar 19, 2016 | Emerson Refrigerators
Hi! How do I find Sanyo compact ice storage replacement door? Thanks!
I'm assuming that your asking about a freezer door on a compact refrigerator. parts can be ordered on line @ sears direct, go to link below & enter model # or scroll down page & select refrigerators under, find parts by top product categories - scroll to refrigerator brands found - select Sanyo refrigerator parts - scroll down & select your model - select View all parts in this diagram, some parts will be available others you will have to call phone # provided. when looking @ your parts list there will be a exploded view on left ( to see it better click on view full size) http://www.searspartsdirect.com/partsdirect/brands-products/Sanyo-Parts/Refrigerator-Parts
Aug 18, 2014 | Sanyo SR-4910M Compact Refrigerator
Not cooling
i've had that happen to me before it it might be the freon
Sep 14, 2012 | GE 3.1-cu. ft. 2-Door Compact Refrigerator...
Replace door gasket on danby dcr412 compact refrigerator
Hi There,
I'm not sure what you are asking here, however if you are looking to purchase a replacement gasket for this model you can contact the Danby parts department at 1- 800-496-6049
Thanks!
Aug 01, 2012 | Danby DCR412 Compact Refrigerator
I need a new door seal
Im afraid without the model number, which is located inside or outside on the back of your refrigerator, unless the model number tag/sticker/plate was removed or is not readable, finding the correct part would be extremely difficult.
Jun 28, 2010 | Bosch KUL1444 Compact Refrigerator
Aug 21, 2009 | Emerson Refrigerators
My daughter's Emerson CR500 compact refrigerator completely stopped getting cold about four months after we purchased it. It would cost me $57 to ship it to CA to have it fixed, so I'm wondering if it...
My husband and I bought this same refrigerator around 11/2009 and it doesn't work now either. We too bought this refrigerator at a local target. Yikes. We bought ours for our daughters dorm room and it didn't stay working even one year. Is that how Emerson told you to handle it - by shipping that stupid thing to CA. Thats ridiculous.
Aug 17, 2009 | Emerson Refrigerators
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
