Question about Whirlpool Duet GHW9150P Front Load Washer
Water leaks bad when I use the washer, it comes out from all the seams, I got the drawers to set the washer on and it leaks inside them. I stored my books inside the drawer and they were ruined to where i couldnt read em. dont tell me I bought another **** washer that wasnt cheap..oh yah its only 2.
  • 981 Answers
How smart was that with the books? TMI! Get your extended warrantees out, call Maytag Repair to see what bench fees are, and make 'em work. Or:
Just put it wherever you can keep the area under it drained, and if opening it up (unplugged) doesn't show you an obvious loose hose and/or splatter zone, connect the supply water but ease the supply water pressure down. Try to find out why something worked loose and get it clamped on more permanently next time while not destroying useful safety mechanisms. Usually on washers the hot inlet valve fails after some point and you can get a replacement block to swap in from Sears/Maytag or the plumber/appliance supply shop (e.g. Mar-Beck.)
The thing has some cool features to it, but the design needs some looking after and rework because the workmanship is flaky.
I hope you feel kind of craftsy and can find the service manual online.
Posted on Aug 02, 2008
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
Water leaks from the sides when I turn the washer on
OMG i got bad news for you the top seal and bearing is bad you need to compleatley diasemble this machine to replace this normaly while im in it this deep i go ahead and replace the gear case if i had to pay for the parts and labor to do this i would buy a new washer.
Jan 16, 2009 | Maytag Performa PAV2200
WATER COMING OUT FROM DOOR AND DRAWER
On this washer  the seal was replaced ?Did it stop leaking after the seal was put in ? Front load hatch on this is in front area located on the bottom(base).Remove the front  to gain access and you can now reach the pump and  look for any blockage.After  you have found and removed the blockage,run the washer again and if any water leaks remain call your local  servicer .You may have a bad front boot (seal) or its just loosened and it need to be re- tightened.Any water leak should be repaired ASAP so you dont have even more damage to the machine and your home.If the repairman cant stop the leak on his first visit than have the Boot replaced on his second visit.
May 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
