Question about Sport & Outdoor - Others
How do you install the Easton choke up knob? - Sport & Outdoor - Others
Does easton -3 bbcore bat wear out over time?
The short answer is slightly, yes. BBCOR bats are basically metal bats that have similar pop as a wood bat. They do decrease in ball-off-bat speed over time, but it isn't too noticeable.
Apr 07, 2014 | Easton XL1 BBCOR BB11X1 Adult
Choke knob is very hard to pull? What could be wrong and whats needed to fix?
There is a tension adjusting bezel at the base of the choke knob. Loosen it to free up the choke action. It is a black plastic ring around the choke shaft. If the choke cable itself is not seized up, this should do the trick.
May 30, 2011 | 2002 Suzuki VL 800 Volusia
How to replace the choke on a 2000 fxstd
To replace the "choke" on the carb of your 2000 Softail, you much take the carb off the engine. Take the air filter cover, air filter, and air filter backing plate off the engine. Loosen and disconnect the throttle cables and fuel hose. Loosen the nut on the backside of the "choke" knob and take it out of it's slot in the bracket. Twist and pull the carb out of the intake manifold bringing the "choke cable" with it. Once out, use a 14 mm open end wrench to unscrew the cable and plunger assembly. You'll have to swap the spring and plunger from your old cable to the new cable and reinstall in reverse order. Always install a new carb seal where the carb pushes back into the intake. Make sure the throttle works smoothly and snaps shut when you relaease the throttle grip. Never lubricate the "choke" cable. Be careful when tightening the nut on the backside of the cable knob end. The assembly is made of plastic and breaks easily. To adjust the tension on the cable. turn the knurled ring just behind the choke knob.
Good luck
Steve
Jan 25, 2011 | 2004 Harley Davidson FXSTD - FXSTDI...
I need directions on how to fold a 5' Easton Multi-Net....
Go to the link below scroll down to the videos and it will tell you how to fold.
http://www.eastonbaseball.com/5-pop-up-multi-net.html
Good Luck
Dec 04, 2010 | Easton Synergy Cnt Softball Bat
I've lost my instruction manual for how to break down my Easton 5-1 pop-up net.
Check out the following web video to show how to set up and take down Easton pop up nets.
Pop up Instructions
Oct 02, 2010 | Easton Synergy Cnt Softball Bat
My 7' easton pop-up net has gotten twisted and won't set-up correctly. How do I fix this?
the chain on the pole of my easton pop up net has pulled out and went down the other tube what should i do to get it out
Jul 16, 2009 | Sport & Outdoor - Others
Choke won't open or close
I think your bike has a CV carb which doesn't have a choke.It's called an enrichener. Pulling out the "choke" knob merely dumps more gas into the carb. If the bike starts normally with the knob pulled out, you do not have a problem. On a cold/cool day, pull the knob out and start the bike. If it idles faster than normal the system is working. Pushing the knob in should drop the idle speed, maybe stalling the bike if it is not fully warmend up.
Apr 18, 2009 | 2006 Harley Davidson XL 883 Sportster
Bike won't stay running
Have the carburators cleaned. this is the first step to ensure there isnt any dirt in the carb.
2nd. Jets should be standar.
3rd. The Fuel/Air screw or knob should be properly set. This is usually 2.5 turns outward from full close. Check for the manual for the proper opening.
4th. Idle knob maybe set too low.
Mar 13, 2009 | 2005 kawasaki VN 800 Vulcan Classic
Sport & Outdoor - Others Logo
540 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
