Question about Elna Quilter's Dream 6003Q
The thread clicks when it goes around the bobbin and I have to stop sewing as it makes a big knot on the back of the fabric. I have cleaned out the bobbin case but it is still not sewing properly. It was sewing fine until I ran out of bobbin thread and changed the bobbin. Help please I love this machine. Thanks.
  • Elna Master
  • 1,564 Answers
Hello Supernana.
Check to see if you have your bobbin in upside down. If your machine requires it to unspool from one side having it spool from the other side (counter clockwise vs clockwise) can cause you problems like this. Your manual should tell the correct direction. My machine (Brother) for instance requires that the thread to pull counter clockwise direction.
Sylvia
Posted on Mar 17, 2011
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
I have 3116 singer machine, the stich is not grabing the bobbin thred and it is making a knots in the back of the fabric what should i do?
Bobbin thread is backwards.Turn the thread around before inserting it into bobbin locaction.It MUST be put in correctley or this problem will never stop.Check your threading Bobbin Instruction CLOSLEY,I found this out the hard way too.Good Luck.
Dec 05, 2011 | Singer 3116 Simple
I hit a pin with my Singer Stylist 7258. It jammed. I changed the needle, rethreaded it, and turned it off and on, but it snarls up thread under the fabric, and seems that the thread does not always loop...
Good that you changed the needle. Did you rethread just the needle or did you rethread the machine? You may have already taken these steps, but if not, here is what I would suggest:
1. Replace the old needle (which you did), even if it looks ok, as it may be bent or have a tiny burr or other damage that isn't easily visible. Make sure the needle is seated properly - facing forward and fully inserted.
2. **Completely rethread the machine, making sure the thread is going through the take-up lever. It can easily pop out when the machine jams, and you can't always see that the thread is out of place. That could explain why the thread doesn't loop properly around the bobbin.
3. Remove the bobbin and clean any knotted thread or lint from around the bobbin carrier. Canned air is great for cleaning the lint.
4. Replace the bobbin, making sure the thread-end is clipped neat, not frayed or knotted.
5. Try sewing on some practice fabric to make sure the stitches are going to form properly before returning to your sewing project.
Apr 01, 2011 | Singer Sewing Machines
Machine will stitch for a few stitches and then stop and beep.
Your problem is most likely that you've run out of bobbin thread (or about to and the bobbin thread is now loose around the bobbin), your top thread is broken/about to break, or you have a birds' nest (a messy knot of thread) forming underneath the fabric/presser foot and/or within the feed dog. Upon occasion, it's a false alarm. Remove the fabric from the machine and clip your threads. If your bobbin and top thread are fine, place your fabric back in and start sewing again. If you get the stop and beep again and the threads remain unbroken, try rethreading both the top thread and the bobbin. Should you still get the alarm, hit the button to start and see if it resolves itself after a couple of tries. If it doesn't, afraid you have a problem I haven't encountered yet. But so far, the above steps have always resolved the problem for me in the last 6 years.
Mar 04, 2011 | Singer CE-100 Futura Computerized Sewing...
How do I adjust the bottom tension? Thread breaks, knots up under fabric
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Singer 3116 Simple
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
May 25, 2009 | Bernina Activa 140
Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 16, 2009 | Sewing Machines
Sewing Machines Logo
119 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
