Question about HP Pavilion dv2700t 2.5GHz Intel Core 2 DUO Mobile T9300 4GB 320GB DVDRW DL LS WebCam 802.11a/b/g 14... (KQ654AA) PC Notebook
Hi, I have a HP dv2700 laptop. It has been working fine for about 3 years until recently when it suddenly stopped working. At the moment I see the blue light around the power connector blinking all the time if I insert the power adapter. And moreover if I try to turn on the power button the power LED blinks thrice and then goes off. This is all that is happening. Can someone advice me on what is wrong with this machine? Thanks
  • gurpreet_cpq Mar 17, 2011
    Thanks for your reply. I tried what you mentioned but that did not seem to work. :(
    I removed both memory cards and tried them one by one in both slots. But the same problem.
    Anything else that I can do now??
    Thanks
    President:
  • 2,653 Answers
Usually three flashes indicates a problem with the memory. I would take out both chips or one if you've only got one ;)
You'll see a panel for memory on the bottom of the laptop, carefully remove both modules, and try booting with just one, if it doesn't work in the first slot, try the second, if neither works repeat with the other module.
Let me know what happens.!
Posted on Mar 17, 2011
  • 1 more comment
  • RescueTechLA
    RescueTechLA Mar 17, 2011
    You can try the same but this time without the hard drive and dvd drive attached and also the battery. If that doesn't work then usually the DV2000 series has a factory defect with the video card. You'll need to reflow the GPU using a heat gun.
    let me know what happens and i'll give you some real world advice.
    Sure I will try this. But will take sometime to try it out. May be in about 10-12 hours. Anyways thanks a lot for your help. I will keep you posted on the developments.
    Thanks
  • gurpreet_cpq Mar 18, 2011
    I tried to do all that you mentioned but again the result remains the same :(
    The LED ring around the power connector also keeps blinking when I insert the power adapter. Can you please tell me about what you wanted to mention about doing something if all this failed.
    Thanks
COOLING FANS HAS STOPPED WORKING in my laptop. HP Pavillion DV2700 dv 2915nr
If your computer still works, turns on and boots the OS. Then it's most likely just the fan it's self that is bad.
Aug 05, 2011 | HP Pavilion dv4000 Notebook
Hi I have HP dv6767tx laptop which i purchased in april 2008 But 1 year ago, all of a sudden a bright strip around 1 to 2 inches in thickness appeared on the extreme left of the lcd screen. Affected...
very sorry to tell you that the lcd has gone bad because your laptop shows exact symptoms of this case.
As per what some HP costumers have told me HP takes this as a physical damage and does not give them a warranty even if it is in the warranty cover
Finally you will need to get it replaced
This is the most expensive fix after a motherboard and may cost you $180 or 8000-9000 INR
Jul 26, 2011 | HP Computers & Internet
How can i get the drivers of my laptop HP pavilion dv2700 Notebook PC
Download HP pavilion dv2700 Notebook PC drivers from the below link
http://tinyurl.com/dv2700drivers
Jan 13, 2011 | HP Pavilion dv6000z Notebook
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
Apr 26, 2010 | HP Computers & Internet
Dv2700 when starting laptop only goes first screen
If it will boot from the windows disc, install the disc and boot from cd. When windows loads, go through the start repair or recover.
Aug 30, 2009 | HP Pavilion dv2915nr Notebook
Advent 7113 will not read cd drive
This could be the lense giving up.
Try a few different disc type (eg CD's DVD's CDrom, DVDrom etc) - if any of them work, that should indicate the laser is fine all round.
I'm trying to sort my Advent 7110 laptop at the moment, you haven't a recovery disc have u? LOL! Seriously though have ya?
May 10, 2009 | Computers & Internet
I have a recently purchased HP DV6000 Pavilion notebook. It recently began melting the power cable (the rubber portion). I bought a new univeral power adapter (Targus). It melted the attachment heads on...
Please check to see if your system falls under the purview of this HP alert by clicking here.
They have had some issues with their hardware on these notebooks...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion dv2700 is NOT starting, only 7 beeps: 4 beeps pause and then 3 beeps. What's wrong ?
HP Romania give me the answer, RAM failure, i replace the RAM and everything is working fine, thank you HP Romania !
Dec 20, 2008 | HP Pavilion dv2000t Notebook
Frustrating Keyboard Malfunction (HP Compaq NC6000)
please tell the solution of this problem of keyboard
hp nc6000 mobile technology
Oct 22, 2008 | HP Compaq nc6000 Notebook
Hp laptop suddenly turns off
well..the battery is either unhappy(needs a full recharge) or it's dying..or it's an internal charger issue.
May 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2700t 2.5GHz Intel Core 2 DUO Mobile T9300 4GB 320GB DVDRW DL LS WebCam 802.11a/b/g 14... (KQ654AA) PC Notebook Logo
172 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
