Question about Sharp R-1500 Microwave Oven
I have a Sharp Carousel R1470A microwave and the button that opens the door cracked. How do I get it off to replace and where can I get a replacement button?
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave R-1601
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 01, 2007
SOURCE: Sharp Carousel Microwave R-1601 - Need to Replace Door
we cannot get our light options to work. We changed the light bulbs and had no success. Any suggestions?
needing light!
Posted on Feb 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave removal
Actually, you shouldn't need to remove it from the wall to change the door switches or latch head.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have a partial service manual for that unit at our site, and it has the wiring diagram (helpful to be sure it all gets back right).
The manual is at http://www.microwavedisplay.com/r1380_r1381_sm.pdf
Feel free to contact me directly if you have other questions.
Posted on Mar 31, 2008
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Sharp carousel door often won't open when I push the door release button in.
Take the cover off end take a look how the hinges are mounted on it, If they are bolted on they can be readjusted, He man, Use your brain .
Oct 21, 2012 | Sharp Carousel Microwave Ovens
My sharp carousel microwave only works when I depress the door knob halfway down. What could be wrong ?
All microwaves have a safety lever or switch that prevents the unit from working if door is not closed all the way. Most of them you have to take the unit apart as access to it is from inside--what happens is when door is closed the latch or door moves the lever--seen a number where lever is loose or even the holder for it cracked.
Most shops are familiar with this and it should if the problem not be a real expensive repair.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
My microwave wont turn on. the power works, clock, timer and all electrical is working, it just wont turn on.
Most likely you have an interlock microswitch problem or a latch problem. as you just open or just close the door VERY slowly listen for 3 distinct clicks one for each of the 3 interlocks. Two you will hear as you press the door open button and the last one you will hear as the door just opens or closes. If you do NOT have 3 clicks you have a bad micro-switch.
The micro-switches you can purchase on line here:
http://www.repairclinic.com/Sharp-Microwave-Switch-Parts
Owners manual: (Provided only for telphone contacts in first 2 pages.)
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R530ES.pdf
I think you just have a simple micro-switch problem. However... if the latch assembly that holds the switch is cracked or broken it will have to be replaced. I have seen the plastic latch assembly fail causing the switch not to work properly.
Thanks for choosing FixYa,
Kelly
Jun 28, 2011 | Sharp Carousel R530EST Microwave Oven
The push button that opens the door on our Sharp Carousel R-1406F over the range microwave, is broken. We can push it in but it gets stuck. I cleaned it out because it was kind of dirty but it didn't...
It may be the door open button or the door button lever. Sometimes grease is the culprit, other times the surfaces where these two meet get worn, making the door harder to open.
You can find the full service manual free at our site here.
You can find Sharp part at the Sears Parts Direct Web site hereimage-4235112-10659157 or Encompass here.
You can find links to helpful exploded view diagrams and part ordering help for other brands here.
Jan 01, 2011 | Sharp R-1405 / R-140 Microwave Oven
Looking for a carousel with the three roller wheels for our sharp r1470a microwave.
That's the "turntable support" part number is FROLPB017MRK0
(note the difference between ohs and zeros)
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Apr 25, 2010 | Sharp Microwave Ovens
I need to replace the plastic button that is pushed to open door on the R1470a Sharp Microwave. where can I purchase this part?
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find handy exploded views at the Sears Parts Site.
here. (Part prices for Sharp parts is usually best here)
I recommend that you bookmark that link to your favorites.
Dec 12, 2009 | Microwave Ovens
Sharp R-1500 Microwave Oven Logo
119 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
