Looking for advice on how to clean drain hose on LG TROM 2277HS
  • 5,081 Answers
You can download the manual for your model in the below link
Service manual
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Owners manual
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Owners_Manual.pdf
Posted on Mar 17, 2011
How do you clean the drain filter in a lg trom?
How to Clean the Filter on an LG Tromm Washer eHow Follow the preceding link for a really good instruction. I hope this helps you!
Nov 07, 2015 | LG Washing Machines
LG trom wASHER wm20160W WONT DRAIN
Start by getting to the drain on the pump there should be a hose hooked to the pump and there may be a filter that u can clean out. Check the pipe and make sure it is clear and also check the discharge hose to be sure it is clear as well. By the way do u hear the pump come on or try to. If lines are clear and the pump is running then you most likely have a bad pump,
Apr 20, 2014 | LG WM1814CW Front Load Washer
Leaky washing machine LG
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jan 16, 2013 | LG Washing Machines
Good Morning Sir/Ma'am, We own an LG WM2233HW with an "error code of OE" which means "Drain hose is bent or clogged" and/or "The drain filter is clogged". I have checked both. I straightened the drain hose...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!! !
Aug 30, 2010 | LG WM2233H Front Load Stacked Washer /...
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Is there a lint trap on there a 2277HS LG washer
yes, underneath lower access panel on front of machine. be sure to drain water 1st via small drain hose.
Jun 12, 2010 | LG WM2277H Front Load Washer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washer
Anne,
The lint filter is clogged preventing the pump from draining all the water from the tub. Open the little panel on the front lower left of the machine, unscrew the lint filter and clean it. Make sure you drain the trapped water first (before you remove the filter), by pulling out the little rubber hose (you'll see it) and removing the plug from the end.
BW
Apr 02, 2008 | LG WM-2277HW Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
469 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
