I have mercury kvm800m v1.6A mainboard.It detected SATA hardwares.I want to connect SATA hard disk foe it.So I ask from a technition about that.He said your mainborad would have update BIOS.For it need a floppy and some bios update files need to save floppy.Then PC boot from the floppy.But I cant find the files that I need.could you can help me please.........
  • rukshikanm Mar 17, 2011
    I have mercury kvm800m v1.6A mainboard.It detected SATA hardwares.I want to connect SATA hard disk foe it.So I ask from a technition about that.He said your mainborad would have update BIOS.For it need a floppy and some bios update files need to save floppy.Then PC boot from the floppy.But I cant find the files that I need.I also tried _ http://www.mercury-pc.com/downloads.php# .but they said that file not available.
    Scholar:
  • 82 Answers
Go to the following link, use the drop down tabs to select your specific motherboard product. From there it should give you a BIOS flash utility download under the "BIOS" section of the downloads. Hope this helps!
Posted on Mar 17, 2011
    I tried this link.but at last they said "The file you have chosen to download is currently not available on the server." So what I do next????
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
I have Mercury KVM800M VIA socket 754 M/B is not displaying anything.Please give me jumper settings detail.ok bye.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 14, 2011 | Mercury KVM800M Motherboard
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
SATA Hard disk 500GB and Sata CDROM
Could be a problem with SATA drivers. Just try to disable sata support by entering bios setup if applicable.
OR
Find the drivers for sata device and install
Feb 20, 2009 | Mercury KVM800M Motherboard
Sata Hard disk and DDR 1Gb Ram not supporting to my motherboard how can i add and detects this both things please give me reply as soon as possible
Do you have a SATA Cable for your SATA hard disk?
What are the spec's for your RAM, it should be 2 x 184 pin DMMs, 400 MHz, 333 MHz,266 MHz memory. up to 2 GB Ram.
Jan 23, 2009 | Mercury KVM800M Motherboard
Unable to detect 160GB SATA HD... as the message says "the number of disks is not adequate to create a RAID " Please help me outta this problem
you need to go into your bios and change it from RAID mode to IDE(yes i know youre using a sata). when your computer first turns on you should be able to see which key you need to press to enter your bios.
Dec 19, 2008 | Mercury KVM800M Motherboard
Not able to install windows
During the install you must press F6 when instructed to install your SATA drivers from floppy disks.
May 18, 2008 | Mercury KVM800M Motherboard
My mercury motherboard cd was lost
HI,,,,,,,,
i have problems with my mainboard.
for i need mercury mainboards instllation cd
i had tried on kobian.com but thre is no current downloads
plz guide me for solution
Mar 22, 2008 | Mercury KVM800M Motherboard
Computers & Internet Logo
411 people viewed this question
David Payne
David Payne
