Question about Frigidaire Dishwashers
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ? The dishwasher is approx 4 years old.
  • 5,081 Answers
As you have already done the vinegar cycle and all now it must an technical reason.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Posted on Mar 17, 2011
Bosch dishwasher dw44zp/16 dishes have soap residue and are not clean
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 02, 2011 | Bosch Dishwashers
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Any chance I can service my GE Dishwasher myself and eleminate soap residue from sticking to all the dishes?
Hi
Daniel
Feb 16, 2011 | GE Dishwashers
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
Dishwasher leaving white powder residue on dishes. Why and how to fix?
I have a Bosch also with a similar problem. I cleaned everything that I could (lower screen, etc.) and still had scum. I do have hot and softened water and neither fixed it.
Here is a cheap solution. If it does not work, you are out some vinegar. I started the rinse cycle, once it was full of water, used 1 cup of white vinegar dumped it in the bottom of the washer and ran it through. 20 min. Then ran another rinse cycle to wash it down. Next load came out 5 stars! Just like new. The vinegar can be corrosive if left in there for a long time, but it breaks down a lot of the mineral build up. Very acidic. Hope it works.
Jan 07, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishes are cloudy and residue builds up on dishes
I have a Bosch also with a similar problem. I cleaned everything that I could (lower screen in bottom of washer, etc.) and still had scum. I have hot and softened water and neither fixed it.
Jan 03, 2010 | KitchenAid Dishwashers
Why is my dishwasher leaving a scaly white residue all over my clean dishes? I did not do this before and is only about a year old.
I had a similar problem. I cleaned everything that I could (lower screen, etc.) and still had scum. I have hot and softened water and neither fixed it. If your water is not soft or hot, you may be out of luck.
Here is a cheap solution. If it does not work, you are out some vinegar. I started the rinse cycle, once it was full of water, used 1 cup of white vinegar dumped it in the bottom of the washer and ran it through. 20 min. Then ran another rinse cycle to wash it down. Next load came out 5 stars! Just like new. Hope it works.
Dec 07, 2009 | Kenmore Dishwashers
Residue on dishes and glasses...i use rinse agent, and clean regualrly..a sudden problem
Nov 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
White film on dishes/not rinsing properly?
Buy a name brand powder (like Electrosol or Cascade) and use less than full in the dispenser cup.
Do not use gel or tablet, ever.
Final option: (the perfect fix, expensive, but worth it... install a whole house water softener and cut the use amount of detergent in half that you use in both your dishwasher and clothes washer. You will love it.
If problems continue, have the heating element checked/replaced. When it fails, you will always get film/residue on dishes, especially your glassware, even if your water heater is set to the proper temp of 120 degrees.
Good Luck!
Apr 01, 2009 | Dishwashers
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
111 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
