Question about Canon PIXMA iP1800 InkJet Photo Printer
Hi i have a canon ip1800 the warning says ink absorber full , how do i reset this ?
  • 2,574 Answers
Here's How :
1. Press Resume button and hold for 1 - 2 minutes
2. Open the cover
3. Release the cartridge and then put them on again
4. Close The Cover
5. Turn off the printer
6. Turn it on again.
-OR-
You can use IPtool software to reset the ink absorber.
Click here to download the iPtool software.
Step 1 : Manual for service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
5. Open IPtool then click "Reset Main"
Posted on Mar 17, 2011
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
Canon ip1800 ... ink absorber full
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
i hope this helpfull
please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 23, 2011 | Canon PIXMA iP1800 Printer
My Canon iP1800 ink absorber is full.
The following reset method has tested and work perfectly to reset waste ink counter. Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
May 28, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Can I fix my full ink absorber myself? Canon iP1800
Only service centre can help you to replace the ABSORBER KIT.
May 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I try to print on my canon ip1800 but it says the ink absorber is full how do i fix this
Hi It is a pad inside your printer witch absorbs the left over ink when it cleans itself this pad is full there only one way and that is to open it up with a screw driver it a messy job and put some other pad in place of it after any thing just to absorb the left over ink
Jan 22, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to remove ink in th full ink absorber?
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc) 2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3) 3. press 'resumet' ( the button below the power button of the printer) button twice... 4. release the power button 5. connect the usb cable of the printer to the pc... - a new canon printer shall be found in the list of printers. use it as default printer
Aug 07, 2009 | Canon PIXMA iP1800 Printer
PIXMA IP1800 INK ASBORBER IS ALMOST FULL . WHAT DO I DO TO SAVE THE PRINTER.
When the ink absorber gets full you need to take the printer to the shop. The printer has to be completely taken apart to replace the absorber which covers the whole bottom of the machine. After that you need to get to the diagnostic mode which only Canon techs can do, and reset the absorber counts. In my shop the repair runs around $80.00
Jul 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
How to reset canon ip1800
ink absorber is full contact service" ???????????//
Oct 03, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
193 people viewed this question
old marine
old marine
