Question about HP Office Equipment & Supplies
I have an HP LaserJet 6P printer I have been using for a long time. I recently bought a new laptop that has USB ports and operates with Windows Vista. First of all, will the printer work with Vista? I have seen parallel to USB cables that mention Windows XP but not Vista. Will that cable work, or do I need to download something? Thank you
  • 550 Answers
HP web page http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00808536#A0 3/4 way down says your printer is native to Vista,
good to go.
HP LaserJet 6L
HP LaserJet 6P/6MP Your product is supported 5 5 - Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System HP has a Windows Vista driver solution available for your product. This driver will enable your product's basic functions to work. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. You can conveniently find this driver in your Windows Vista operating system, today. At this time the driver will only be available on the Windows Vista operating system through the “Add a Printer�? wizard. HP does not plan on placing this legacy driver on www.hp.com. The adaptor USB-Parallel, (example) http://www.usbgear.com/USBG-PR1.html are plug n play, supported by Vista, the pc sees a functioning USB printer, the printer sees a functioning parallel port, The laserjet 6 is listed as supported by the adaptor 3/4 way down the page, good to go.
Posted on Aug 02, 2008
  • AlmostBob
    AlmostBob Aug 02, 2008
    Marked,
    Dont see how you got that from the same page I did,
    thought I should print the page text, saying "Yes your printer is Supported"
  • HP Master
  • 6,487 Answers
This will not work with windows vista that's the big problem..
Hope that helps.......
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Paralell print cable to usb adapter
go to your control panel & delete the printer, shut down & restart turn the printer on after restart see if the computer sees the printer if not try reinstalling if this doesn't work possibly the adaptor
Dec 22, 2011 | HEWLETT-PACKARD LaserJet 6P / 6MP (H3966A)...
HP LaserJet 6p Printer Drivers Downloads for Windows 7
Go to hp.com. Select the support/driver link. Put in your model and hit enter. You will then see a menu with all of the operating systems. select the full download.
Jan 03, 2011 | HP LaserJet 6p Printer
Installed usb to db26F converter to use printer
Ok reinstall as Administrator, use "Compatibility mode" for install and the run .exe, also run software as Administrator. too. Often these devices, USB - Serial Ports are NO GOOD for a printer. Either install a real Serial Port. or get a new printer. Windows 7 will NOT help either, it doesn't like older equipment.
Mar 24, 2010 | HP LaserJet 1100 Printer
Windows 7 driver for Laserjet 6P
you will need an actual parallel port to connect that printer. If the new system doesn't have a parallel port, then I'd either:
  1. Install a parallel Port expansion card
  2. Get a USB Printer
http://www.newegg.com/Product/Product.aspx?Item=N82E16815166007&cm_re=parallel_port_card-_-15-166-007-_-Product
http://accessories.us.dell.com/sna/products/All_Printers/productdetail.aspx?c=us&l=en&cs=19&sku=222-1681
Jan 25, 2010 | Computers & Internet
Proper plug for laserjet printer into my HP 761n desktop
unplug all the connection again.
plug in one item at a time, and wait till the computer finished the detection. If the computer can't detect the USB. try another USB port. till all of you devices are connected.
Apr 09, 2009 | HP Computers & Internet
Windows xp with not recongise HP Laserjet 6p when plugged into a usb port
To my knowledge, the 6P isn't a USB printer, it's parallel port only. Are you using a USB / parallel port adapter? If so, I believe that's the root of your problems - the adapter.
Try hooking it directly to the parallel port (shut the PC and printer down before doing so).
Upon restart, Windows will detect it, and may or may not "know" the model, so you may have to choose it from the dropdown boxes.
If it works when directly connected, you will need to either locate drivers for the adapter (if any), or manually configure it under the printer port properties.
If you need more help, let me know. These are great little printers - once you get them to work!
Dec 03, 2007 | HP LaserJet 6p Printer
162 people viewed this question
Ben Johnson
