Question about Vizio E320VL 32 in. HD Ready LCD TV
Vizio E320VL has a buzzing or static sound coming from the right speaker.
    Problem Solver:
  • 11 Answers
You may have blown your right speaker if you max the sound allot, you may need to replace. Hope this helps- Pleas comment
Posted on Mar 17, 2011
  • 30 Answers
Does this happen on all video inputs? Does it happen when the volume is turned down all the way? There could be two solutions. Solution 1, is the amplifier chip is going faulty on the Main Board. Solution 2, is the Power Supply Board is approximatly 6 inches above the right speaker, and the power supply or the High Voltage Transformers on the power supply are causing the buzzing noise by Electo Magnetic Interference.
Posted on Jan 22, 2012
Static popping and buzzing sounds come from the speakers when the car is running. The Radio is not turned on and it will continue for a long time, quit then start again as you are driving.
Is it a factory amplified system? Could be the volume knob. Might try unplugging the radio for test purposes and see if it still pops and buzzes to get a better idea of where to go next
Dec 28, 2013 | 2004 Lexus ES 330
Vizio E320VL has lost sound
if you have basic idea in electronic repair, you can open the back door using a screw driver to gain access the internal part of the tv. then look for the speaker first if worn out you can also check the resistance using an analog tester. by the way before you do this initial checking you can check first weather the audio is set to off or mute in the settings, also check the volume adjustment .
Nov 02, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
How do you fix a E320VL that comes on and turns off right away.
it sounds like your main board went bad. try to replace it
Oct 18, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Apr 03, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
Vizio E320VL No sound How to get sound back
Look in main menu for set and or in audio menu---look to see speakers are not by accident switched to OFF--this can happen by accident.
Oct 16, 2012 | Vizio L32 32 in. LCD HDTV
My vizio e320vl comes on for a second then goes off
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 29, 2012 | Vizio E320vl 32-inch 720p Lcd Hdtv
I turn my vizio on then it just turns itself off
Tries tv unplug,replug it back like an hour later.By letting the tv resetting itself back to the factory setting.The tv should be working again,if have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a refurbish power supply board for the replacememt.
Jan 30, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
Buzzing static sound in speaker
Static can be caused by a few things.
Does the static persist if you unplug the audio cable from your computer?
If so, the static is being caused by the amplifier built in to your speakers.
If not, the static is probably caused by interference on your sound card. Try plugging the speakers in to a portable media player. You might need to replace the sound card in your computer.
May 13, 2010 | Bose Companion 3 Series II Multimedia...
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio E320VL 32 in. HD Ready LCD TV Logo
511 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
