Question about Whirlpool Microwave Ovens
HAVE A WHIRLPOOL ELECTRIC STOVE MODEL RF395LXE.RECENTLY THE DISPLAY BOARD LIT UP E1 F5. I PRESSED THE CANCEL/OFF BUTTON. THE CODES WENT OFF FOR ABOUT 10 SECONDS AND THEN CAME BACK ON. WHAT DO THOSE CODES MEAN AND HOW CAN I GET RID OF THEM. THANKS, DOUG
5 Suggested Answers
SOURCE: display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Posted on Aug 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi. I pressed the 'quickstart'
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool microwave MH3185XP: cancel button does not work
The symbol next to the Cancel pad means it would also be used to turn the Child Lock feature on and off.
But as it is, you have a failed membrane keypad.
Luckily, on these models you can replace the control panel frame with keypad all as one unit without doing any peel & stick.
Just remove your circuit board and drop it in the new frame.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(There are 12 models which start with MH3185XP, so check the tag on your oven for the full model number.)
See reference number 3 on diagram number 3.
Posted on Jan 29, 2009
dcramer531
  • 1654 Answers
SOURCE: WHEN TRYING TO SELF CLEAN
The E1 - F5 error code indicates that the oven door lock assembly is not operating. The oven will not begin the self clean cycle unless the oven door is properly locked. This failure is normally caused by a failed door lock assembly. In rare instances, it can be caused by a failed control board or a wiring failure. The normal troubleshooting for this problem is to unplug the range and check the wire harness connections between the control board and the door lock assembly. The first image below shows the access information for the components in this model of range. The second image shows the wiring diagram with the door lock circuit highlighted. If you are able to unplug the range and check the wiring connections, you can likely fix this problem yourself. If the wiring connections are okay, the next step in troubleshooting is to replace the door lock assembly (part W10107820). You can order this part from the Sears PartsDirect website. Replacing this part will likely fix your problem. If you replace the door lock assembly and still have the same problem then the electronic oven control board may also need to be replaced. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Posted on Nov 23, 2010
Whirlpool accubake system E1 - F5 error code
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
You can usually find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag here.
Dec 10, 2012 | Whirlpool Microwave Ovens
Error code E1
this type of code normally mean Control Board Problem. You must call to the profesional repairmain. However you can do the following :
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
Sep 16, 2012 | Microwave Ovens
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
WHEN TRYING TO SELF CLEAN OUR KENMORE ELECTRIC RANGE WE GET THE E1-F5 LIGHT?
Nov 23, 2010 | Microwave Ovens
What does error message F5 mean?
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing..
I'm not finding the one for for this model online.
If it's a convection model, F5 would be a damper door sensing error, which is usually a bad switch.
More info on switches is here.
One of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
If it's not a convection model, F5 is probably a sensor error.
On some models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Here's some info from Samsung, which is the actual manufacturer of these ovens:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Feel free to contact me directly if you need more help.
Aug 22, 2010 | Frigidaire GLMV168K Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
