Question about Sony Playstation 3 (PS3) Console
My Ps3 keeps freezing up but only on 1 game. I've already tried switching disc with the same game. Can you help?
  • Bob Maghanoy
    Bob Maghanoy Mar 17, 2011
    what's the game that will make it freeze. Possible the game has an issue.
    President:
  • 2,653 Answers
If it's freezing with the same game it means either one or two things.
Your game data is corrupt, fix them by deleting all instances of the game under Game Data. Make sure you backup your game saves to an external usb drive just in case.
2nd possible reason is you've got a bad sector on your hard drive, if the above doesn't work then I would suggest you swap out your hard drive with a new one. 320gb drives from Best Buy for for $50 so it's a pretty cheap fix ;)
Posted on Mar 17, 2011
My ps3 freezes on disc games but not on down loaded games.
Make sure disc are clean,,of dirt and smudge,,fingerprints,,thats usally the cause,,,and reset ps3,,,hold down power button till cutts off ,,repeat,,holding till u hear a beep,,keep hold,,,next,,2 beeps,,realease quickly,,connect usb on controller,,,do number 2 option,,should help,,update also,,,and clean and blow out ps3 of dust,,,use a disc cleaner,,good luck
Nov 12, 2012 | Video Game Consoles & Games
Had a Power Surge and now my PS3 will not send a signal to the TV. Yes, PS3 was plugged into a surge protector, but it failed. I can turn on the PS3, put disc in and eject them with no problem. The...
If its been reset it will originally not display video out HDMI, first try component cables. Then try this...
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to Sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your back-up you made prior to doing factory/hard reset (optional, if you created a back-up).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
- Freezing when doing anything
- No harddrive activity
- Freezing when trying to use onboard keyboard or bringing up keyboard
- Game/movie disc freezes system
Jun 02, 2011 | Video Game Consoles & Games
How to reset everything on my ps3?
Hard Reset procedure for the PS3 (as instructed by Sony CS). Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
Arvind S Iyer
Oct 17, 2010 | Sony PlayStation® 3 (60 GB) Console
My game keeps freezing up, what is the problem and can it be fixed?
Hi. There are many possibilities why PS3 keeps freezing up to a certain point of time. First is, this could be a game disc issue. Ifthis happened to a certain game disc only then probably you might have a purchased a bad game disc. Second is, lens problem. might be the lens is getting hard time reading the disc and needs replacement.
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
The game keeps freezing.
Assuming you've already cleaned the disc, all you can do is delete the game data. In the crossbar (XMB), go to Game->Game Data Utility. This will delete any patches or game data that have been installed since you first put the disc in. Then PS3 will re-install/re-download the game data. This will not affect Save Games, as those are stored in the Save Data Utility.
Jul 23, 2010 | EA - Electronic Arts Mercenaries 2: World...
My ps3 keep freezn whats wrong
you may want to try a hard reset. it is a last resort but should clear your issues.
If it works be kind and leave me a short testimonial for my help. Thanks
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 freezes while playing certain games..i.e. God of War3 and Assassins Creed..What's the problem?
try updating firmware or doing hard reset.
this is a last resort Sony support recommends.
Apr 09, 2010 | Sony PlayStation 3 Slim Black Console
Since i got assassins creed my ps3 was freezing a lot
Oh dear, i'm afraid to say you've got one of the 'fatal' error codes. The error you're encountering means there is a major problem with the blu-ray drive (you're PS3 is pretty much shot)...sad.gif
The only thing you can do is ring Sony's tech support and arrange for a replacement console. If you are still under their one year warranty, you will get a replacement console free of charge
or if your console still works just dont play that game
if it keeps freezeing its becuse of the blu-ray driver :( you would need to try setting it to factory def's or if that does'nt work try rolling back the firmware upgrades........or just buy a xbox 360..
Jul 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
