Question about Mitsubishi WS-55515 55" Rear Projection HDTV
Fuse blew in my home and power went out to my mitsubishi WS 55517 projection tv. Green light flashes 12 and then goes out. I have no system reset light.
  • 4 more comments
  • bitabra Mar 17, 2011
    I mean it blinks once and then twice
    is there anything else that I could try
    I've tried that one. Unfortunately I do not have multimeter
    My Mitsubishi WS55517 Projection TV still doesnt power on green light flashes 3 and then 5 times
    Noww it's 3 and 5
  • bitabra Mar 22, 2011
    need copy of schematic
    Genius:
  • 1,622 Answers
Hi, if the set is shutting down it should blink a code. Try pushing in the menu and input buttons on the set both at the same time and hold them in for 8 seconds to see if the self diagnosis will falsh a two digit code. Let me know what happens.
Ok yours is a 12 code means the TV is not shutting down for protective purposes. You will no doubt need a service manual to check the power supplies as its probably something real minor in the start up or stand by voltages that is preventing the set from starting. I have a link where you can get the service manual and they provide free support to heklp you diagnose and repair your TV with the purchase of the manual. If you would like the link let me know. They email the service manual after purchase.
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Good luck...
Posted on Mar 17, 2011
  • 4,889 Answers
Do you mean the error code operational check returns an error code 12 or does it blink 12 times?
  • 3 more comments
  • eagle338
    eagle338 Mar 17, 2011
    Ok. That is the error code operational check. Anyways, 12 blinks means no error which indefinitely means its a fault on the power supply as the microprocessor detects and identifies the problems in nearly all other circuits. The first thing we should test are the pico fuses since the main fuse on the power board seems OK. How good are your electronics/soldering skills? I do have a schematic for this model and can guide you provided you know how to use a multimeter and solder.
  • eagle338
    Well you can leave the set unplugged for a few hours to see if it can reset itself. Sometimes the set just goes into "Protect Mode" when a surge occurs and it resets itself if you leave it unplugged. If that doesn't work then component level repair is the only solution.
  • eagle338
    Its ok you can borrow or buy one provided you believe you can pull this off, with my guidance ofcourse. If you do not have any prior experience in working on electronic circuits then its not advisable to handle high voltage electronics as these things hold residual voltages for several days after they have been unplugged
  • eagle338
    3 and 5? You told me it was 1 and 2? Which of them is it?
  • eagle338
    Ok. 35 is a bit easier to solve. It means that the fan on the DM board is not working correctly. It can either be due to loose/faulty connector or the fan itself is damaged. Re-plug the fan connector and see if the problem is solved. Will you try to do it yourself?
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
TV will not turn On
Call a good TV Tech and have him check for vented capacitors in the DM module or blown pico fuses on the -24 and the +24 volt lines.If fuses are blown,it indicates the convergence amp IC's are bad.The fuses solder into the board.
Jul 28, 2009 | Mitsubishi WS-65711 65" Rear Projection...
WS 65313 Mitsubishi went black all of a sudden
hold down the menu and input buttons after it shuts off it will flash with a code. call tv repair place and they can tell you what code means.
Jun 04, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55515 55" Rear Projection HDTV Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
