Question about Troy Bilt Tb70ss Gas Trimmer
Hello, I can start my 4-cycle weed eater on the choke position and stays idle although it should not. I move the lever to position 2 and the 3 and the engine runs at the same speed. If I accelerate, the engine dies... Help!
  • Troy Master
  • 7,482 Answers
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
    It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
    Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
    My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
    This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
    Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
    What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
    50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
    Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
    These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
    Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
    May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
    Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
    remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
    Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    31cc Ryobi weed eater engine will start, then stall shortly after
    you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
    May 24, 2009 | Black & Decker 19" Electric Lawnhog...
    Troy Bilt Tb70ss Gas Trimmer Logo
    82 people viewed this question
    Top Troy Garden Experts
    Matt Olenzek
    Matt Olenzek
    Wade Mobley
    Wade Mobley
    Mike Squire
    Are you a Troy Garden Expert? Answer questions, earn points and help others
