Question about HP Officejet 7210 All-In-One InkJet Printer
Replacing black inkjet cartridge
'something' is stopping the black cartridge from being removed.  I can get the small cover raised (though it's stopped by the grey thing behind it) but can NOT get the white 'bar' in front of the two cartridges (color & B+W).  What do I move to GET the cartridge out and the new cartridge IN?  Thanks!
  • Anonymous Dec 05, 2008
    can't get the new cartridge in
I got a notice that the black ink cartridge was empty. I got a new #96 cartridge. The tray that the two cartridges sit won't move & the lip oh this tray restricts access to inserting either cartridge. This sliding tray is about 3 inches away from the right side. I tried disconnecting & reconnecting all leads to the back of the printer when the power was on as well as being off . The tray won't move please help.
Posted on Nov 20, 2008
  • 345 Answers
Are you trying to change the cartridges while the printer power is in the ON position? If not, plug the printer in and open the cartridge cover and the bottom bar should move down and then open the top cover over each ink cartridge and pull the ink cartridge toward you.
Good luck
Posted on Nov 15, 2008
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
5. Plug the printer back to the power source.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
How to change ink cartridges on MP 240
Turn the machine on, open the cover and wait for the cartridges to come to rest in the centre - they may make several passes backwards and forwards until they stop. Push on the clips and the covers will raise. Remove the cartridges, replace with new ones, close the covers until they clip into place then close the machine and you are done.
Oct 05, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How to install ink cartridge
Dear Sir,
Plz folow This step to solve your problem,
  1. Step 1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
  2. Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  3. Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  4. Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  5. Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  6. Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
Thanks For Your Time,
Apr 24, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Power switch blinking
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Nov 12, 2009 | HP DeskJet 3740 InkJet Printer
Not printing, on light flashing
Nov 08, 2009 | HP DeskJet 3650 InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Light constantly blinks
Oct 20, 2009 | HP DeskJet 3520 InkJet Printer
How do i change the black ink cartridge on a lexmark x2580 printer
With printer on and connected to computer do the following:
Open top cover.
Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
Wait for ink carriage for taking position in the middle of the printer rail.
Open cartridge top cover.
Pull cartridge toward yourself and snap it out.
Do the same in reverse order to fit new cartridge.
Remember to remove cello tape strip from new cartridge nozzle.
Do alignment procedure after replacement.
Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Aug 20, 2007 | Lexmark P315 InkJet Photo Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
