When i turn on my aircon the fan won't work but the compressor is working... i heard humming sounds and there is no air comes out.
    Sergeant:
    Novelist:
  • 185 Answers
You could have a bad condensor fan motor..... Shut the AC off at the Service disconnect and spin the blade on the fan motor and then while it is still turning turn the AC back on if the motor takes off and starts to run then you have a run capacitor out. Which is a cheap fix. Also on some model they add a fan cycle control to help the AC main tain head pressure in low ambient conditions. It will start on its on when the head pressure makes the pressure switch and then shut off if the pressure drops below its set point.....
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,
always use a test meter to ensure the circuit is, in fact, de-energized.
IF YOU ARE NOT ALREADY SURE YOU CAN DO THIS JOB
SAFELY AND COMPETENTLY
REFER THIS WORK TO QUALIFIED PROFESSIONALS.
Posted on Mar 17, 2011
Testimonial: "thanks! =)"
Air conditioner and fan will not come on ,when set a hum is heard for 15-20 seconds then shuts down
Sounds like a bad run capacitor on the outdoor fan motor. Compressor kicks on but quickly overheats because fan is not running. Good Luck!!
May 12, 2017 | Heating & Cooling
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
1999 vw beetle, a/c suddenly stopped working, fan blows and light comes on, but compressor doesn't
Have the aircon gas checked. If there is a leak in the system the pressure will be to low and the compressor won,t kick in. Re-gas aircon and check for leaks.
Jun 08, 2010 | 2000 Volkswagen Beetle
Aircon relay wiring burnt, squeaking sound heard from the compressor. Help? thanks.
Have your compressor check. Squeaking sound is caused by a metal to metal contact. Your compressor bearing needs to be replace, to get it aligned. So that the metal to metal contact will be eliminated. Reload your compressor with refrigerant, before getting it activated. Replace the burnt wiring and the relay. Since a lot of work must be done, it is suggested that you take this to the car aircon service
center.
Nov 03, 2009 | 1994 Nissan Sentra 4-Door
I have a Mazda mx6 and the aircon won''t work.
what won't work? the interior fan or is all else well except the cooling part? if the compressor does not come on, then perhaps you need to refill gas. in the very front of the car under the hood, you remove the plastic covers where the hood opener is, and you will see some pipes & a canister. on top of this canister there is a clear small round site glass, you can check there for gas if you have dye, or you can unscrew the cap over the refill nipples and depress with you finger nail, air (gas) should blow out under good pressure, not a little only. there is also a fuse you can check situated in the same place, this is for the compressor
Jul 02, 2009 | 1997 Mazda MX-6
Aircon compressor makes noise
Is this noise definately from the compressor? have you looked round the system for a loose componant like the fan? is this system a heat pump sorry I have not checked online but if it is what is the sound like in heat mode, if just coling unit please ignor last.
Jun 08, 2009 | Sanyo CM3172 Air Conditioner
Noisy Aircon
Your compressor ismounted or rubber feet. If one or more of these rubber spacers is gone or loose you need to come up with some more. If these are still n place its possible that the compressor (which is mounted inside the black oval or round case) may have a broken spring. In this case its compressor time Im assuming your fan is ok as you say its only when the cooling is on. Only 4 things move on the AC 1= inside fan 2= outside fan 3= fan motor and 4=compressor& compressor moptor which are in 1 case.
If you need to know more add on more information but I believe if youve gave me all you can thhin of its something to do with the compressor.
OH yes FYI if the outer case of the compressor is round you have a rotary compressor and they arenatorious for being loud and viberating even when new. If you decide its inside the compressor Id suggest replace the whole thing cause the compressor viberation causes tyhe copper lines to become hard and can crack eaisly.  Hope this helps. PLEASE Grade me ACCORDINGLY and good luck.
Mar 03, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Aircon Compressor problem
Im not that familiar with cars, but if this is a new (90 or newer) then the RPM going so high is because the fast idle switch. It does this to compensate for the extra power being used by the compressor, which isn't coming on at first. Is the electric fan coming on for the condenser coil at the same time as the compressor? You should have 2 fans, one is for the radiator water, the other is for the A/C. There are temperature controlled sensors for these fans on some models. Its possible that may have something to do with it.
Mar 05, 2008 | Heating & Cooling
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
