Question about Kyocera FS-5025N Laser Printer
C5025N SERVICE CODE 7001 AFTER CHANGING BLACK TONER
That is a Toner motor K error: Over-current at toner motor K is detected for 80 ms in total while toner motor K is ON.
It may be caused by Defective drive transmission system of the toner motor K.
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
If this does not help, please replace the toner motor K
Posted on Jun 09, 2011
Sharp MX-181OU-Call for Service. Code: F2-40 How do i fix?
SOURCE:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=MXM363N&code=F2-40
Seems to be a black toner supply issue. Try a different black toner cartridge. Also, make sure the sealing tape has been removed, and give the cartridge a good shake before inserting. Also could be waste toner cartridge, or even the developer, but we always hope for the least expensive option first!
Feb 11, 2015 | Sharp Office Equipment & Supplies
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Oki c321dn 'service call 990:error'
Error 990 refers to the toner capture sensor unit, that black knob looking thing on the toner cartridge itself. I'm betting the error popped up right after changing the toner cartridge?..... therefore, it's a defective toner cartridge.
Aug 14, 2014 | Office Equipment & Supplies
How to remove left and side casing from kyocera fs-c5025n please
FS-C5025N left cover removal.
1. Open the rear cover.
2. Open the top cover.
3. Remove the opening and closing axis from the main unit frame and then remove the top cover. It pry's out at the hinges.
4. Open the left side cover and then remove the one screw.
5. Remove the waste toner box. To remove waste toner box, press the lock lever in.
6. Remove the paper feed unit .
Feb 18, 2011 | Kyocera FS-5025N Laser Printer
Error code 7001:0014607
Kyocera Mita FS-3820N
Hello, This error code (7001) refers to a Toner motor error.
• Toner motor is overloaded. TNMOC is detected by sampling every other
100 ms in 2 seconds since the main and toner motors are activated following
the Replace toner Clean printer, message after the "Toner low" is detected.
Recommended action is to change the toner pack.
If this does not resolve the issue then the developer should be changed.
If neither of those resolve the issue, then likely the internal circuit board called the engine controller may be bad.
If this is the case the printer will need to go to an Kyocera Repair Depot.
I hope this has been of assistance.
http://www.fixya.com/uploads/images/prefab_21.jpg
Jan 18, 2011 | Kyocera Mita FS-3820N Laser Printer
Error code f2-04 after changing to new toner cartridge
F2 04
  • Identification error
  • Model error
  • Type error
  • Destination error
  • Data abnormality
  • Misc error
It is always recommended to use OEM toner. The toner you need if AR-310NT
Sep 24, 2009 | Sharp AR-M257 Black and White Copier
I have a Kyocera c5020n with an occasional error "call service 7001: 0020988. It does clear if I power off/on.
This what it means (7001 is the error code: 0020988 is the page count) -
Toner motor 4 overcurrent detection
error (black toner)
• The engine controller PWB (KP-1054)
detected the overcurrent of toner
motor 4.
Defective toner
motor 4.
Jun 15, 2008 | Kyocera Office Equipment & Supplies
Kyocera FS-5025N Laser Printer Logo
499 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
