Question about Vizio L37 Television
Vizio l37 - orange light on but tv won't turn on
SOURCE: Vizi L37 - won't turn on
mine was doing the same.. just installed new power board and no working tv still.. must be something else..
Posted on Dec 11, 2007
Sgt Fluffy
  • 157 Answers
SOURCE: how do i turn off the orange light on the vizio
That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
Posted on Jul 08, 2009
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
i have a 50 in vizio and the sound just went out. the picture still works but no sound anyone have any ideas on how much to repair it?
Posted on Oct 11, 2009
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Posted on Dec 15, 2010
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
I have an orange only light on my vizio l37. Most solutions suggest replacing the main board. I can't find any schematics telling me which board that is. Can you help me identify it?
SSB board which is also known as the Main board that has cable connector and av inputs on it /
Look for it at Shopjimmy.com type in your Model number.
Jul 05, 2011 | Vizio L37 Television
DVR remote won't work w/ visio tv on. Dish says i need to turn off "power save mode". How is that done?
On the vizio remote go to menu then picture then click the more button then advanced pic then turn off ambient light sensor and bscklight control. I also had to play around with the backlight #
Jun 04, 2011 | Vizio L37 Television
My tv won't turn on. The orange light is on - will not turn green and go on. Have tried disconnecting from power, using remote, manually hitting on button. Vizio L32 hdtv10a
Look at the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
I have the same model for my bed room, my power supply blew up beyond repair, had to buy a used one, now the LCD controller board is going bad when it gets hot. Not a very good TV.
Dec 01, 2009 | Vizio L37 Television
Vizio wont turn on!!
I have this problem. Bought at Costco. Called them and was transferred to Vizio. TV still under warranty, so they are supposed to get me another TV. Mine is only a little over a year old. The one they are giving me is NOT new, but refurbished. I'm not happy about this, but what can I do? Apparently, this IS a KNOWN problem.
Aug 05, 2009 | Vizio L37 Television
I had some water from my plant dripped in my 32 inch Vizio LCD tv. Th e tv was off when this happened, so I try to turn it on and nothing happened. I try to dry it out with a blow dryer on warm heat. It...
You should let it sits for at least 72 hours. does the TV have a orange Vizio logo light when you plug in the power? what about when you turn it on, does the Vizio logo light turns white? if yes to these two questions and you still does not have picture or sound, it could be your main board or inverter that got fried.
Jun 22, 2009 | Vizio L37 Television
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
Tv will not turn on.
my vixio l37 will not turn on neither with the remote nor the power unit ,need some solutions
Sep 04, 2008 | Vizio L37 Television
L37 tv turns off on own and then will not turn back on
I have same problem and i put in a new power supply and this did not solve problem. I will be changing out main board next and post results.
Jan 31, 2008 | Vizio L37 Television
ok I'm just going to copy paste here being as this might work for you guys, I tried it my self but had no luck but my issue has slightly different behavior(led goes green for a second before dieing). any event here is what I found:
source
All,
Check this out:
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Aug 13, 2007 | Vizio L37 Television
Vizio L37 Television Logo
648 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
