Question about Dell (P513W) All-In-One InkJet Printer
I have installed the ink cartridge but they did not snap in as told did they send the wrong ink this is a new printer
    Brigadier General:
  • 10,406 Answers
Then, take it back to where you got it, and get it replaced.
Posted on Mar 17, 2011
How do I install a replacement ink cartridge in an unidentified printer?
are you sure its the correct type of ink cartridge?
are there any shipping protection on the contacts or ink slots at the bottom still attached?
do the old ink cartridge snap into place without problem?
if the old ink cartridge slot in place but not the new. and there is no protective plastic from shipping on the new ones. then it is wrong kind of cartridge
Nov 29, 2015 | Office Equipment & Supplies
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to instal a new printer ink cartridge
Lift the printer unit, and position the scanner support between the tabs to hold it open.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
I was troublshooting my ESP 5 with two new ink cartridges when they told me they would have to send me a new printhead. The new printhead is here, but when I install the cartridges (again and again with...
If the cartridges were out of the printer in the open air,they might have gone dry. Try to reseat cartridges 2-3 times,if isssue persists,get a new colour ink as Kodka will certainly not replace the ink for you.
Dec 10, 2009 | Kodak ESP 5 Printer
Show me how to install new ink cartridge onv305
hi eileenoreill,
you can try these steps:
  2. Lift the scanner base unit.
  3. Press down on the ink cartridge lever to raise each ink cartridge lid.
  4. Remove the old ink cartridge.
  5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
  6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
  7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
  8. Snap each lid closed.
  9. Lower the scanner base unit until it is completely closed
  10. Snap each lid closed.
just update me if the issue is not yet resolved.
Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
Lexmark 2300 Printer/Scanner
SNAP the cover up...literally....SNAP it up...gently lifting it into place does NOT activate the cartridge alignment. Make sure the power is on...LIFT UP THE LID QUICKLY SNAPPING IT INTO PLACE...the cartridge then moves into the middle..
Sep 22, 2008 | Lexmark X2470 All-In-One InkJet Printer
Printer
Hi , use the genuine canon ink cartridge the printer can identified the ink cartridge. and colors.
Feb 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  2. Lift the front cover.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
Feb 09, 2008 | Dell 725 InkJet Printer
Dell (P513W) All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
