Question about Dynex Optical Mouse
I disconned the cable from the back of my lap and later I conneted again but i didn't work.
    Scholar:
  • 62 Answers
Try checking your drivers to make sure they're still enabled and installed. Right click My Computer, click Properties, click Device Manager.
Here you should be able to view your Dynex Optical Mouse under Mice and other Pointing Devices.
If it shows yellow, you'll have to reinstall it/find new drivers for it.
If it's red, simply right click, then re-enable device.
If none of the above work, you might have to reset your BIOS to it's factory settings. I had this issue with a new mouse once. After it reset, it easily picked up my mouse again! Not sure exactly what set it off.
Best of luck! Hope this helps some :)
Posted on Mar 17, 2011
What should I do to enable a terminated a network to connect Internet to my Lap top?
You can open Network and shareing menue and search for any internet connetion in the area or you can plug a ethan cable in the computer and it will do it automaticly
Mar 12, 2015 | Toshiba Satellite C655d-s5130 Laptop, For...
Siemens Innowave 'n890l6u5 rsgs'
sadly you destroyed the unit only option is replacement of same
Aug 11, 2017 | Siemens Microwave Ovens
Philips magnavox tv model 9p5511c101
if it was working ok before then ring up and complain and get him back as he did not do the installation properly.
Jun 09, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Why is my wireless conneted with limited access
Ok,here's the solution,I have my lap top about 100 feet away from my router,have a man cave,I have it plugged in always and when the wind is blowing,my signal will get lost and I get the same reading as you do,but it picks right back up,it's the signal,my vizio,smart tv is connected by wifi and I loose my signal there too,Here's a video to watch,enjoy.http://www.youtube.com/watch?v=Lf1UgEJq8NY
Oct 29, 2012 | eMachines Computers & Internet
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
I have a wired connection and yesterday it was working well but this morning it didn't work. I tried again later but still the same. It's saying that i don't have a valid IP config but when I...
try updating your driver but first try to roll back the driver or press F8 while PC is starting and then select the option- last know good configuration i hope it will work
```PLEASE RATE MY ANSWER AS GOOD AS POSSIBLE```
Jul 03, 2011 | MSI Wind U100-280US Netbook
I have a nokia 6500 slide ,and i have a problem because when i put a ringtone on it ,later after some seconds it come back with nokia tune ,what should i do ?
hi, it could be that you did save the settings after you changed it...try it again and save it...Also, it could be doing that if you remove your memory card and you re-install it, your ring tones and some settings will change...Also, when you connect your phone to an external device like Lap top using USB cable ring tones and some settings will change.
Jun 08, 2010 | Nokia 6500 Slide Cellular Phone
I've had my lap top for about a year now. It used to make me connect to places that allow free wifi. Now, it says "conneted with limited access" even with a full bar signal! What should I do to resolve...
Dont warry not a problem with your laptop. Just find out the service. i am sure right now that wifi system is limited access mode. thats why u get full signal but can't use the internet. Visit to your operator and config your LAPTOP IP with there server. It will start working again then. Thx.
Jan 30, 2010 | Sony VAIO Notebook
Vip 622 rebooting. receiver works when just plugged in,once satellite cables attached, will work for a while then reboots. Can get it going again if take satellite cables off then put them back on. But if...
this problem occurs when the ground on the Dish is not properly connected. What is happening is the cables from the dish are backfeeding voltage and grounding out your rec. Now there could be a possiblity that it could be the rec. however if it stays powered on with the sat in cables discon. then it defintley sounds like a grounding issue.
Oct 20, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I need a pass pahase
you can check the the passphrase on the setup page of the your router. does you laptop connects to the router via an ethernet cable.
reply to this post so I can give the steps on how to check it.
Jun 05, 2008 | Linksys Wireless-G WRT54G Router
Dynex Optical Mouse Logo
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
