Question about Dynex DX-L22-10A 22 in. LCD TV
How do you adjust the viewing angle of the screen. Is the bracket on a ratchet ? Thanks, Terry
  • terrymunt Mar 17, 2011
    Hi Eagle 338, Thanks. This is my mother in laws tv 75 minute drive away. As I recall it has an L - shaped stand that sits on a counter top. Is there some sort of racheting mechanism that allows the tv screen to be rotated in an upwards or downwards tilt? I don't want to have her force it if it is fixed and requires mechanical adjustment. Terry
  • 4,889 Answers
Is it wall mounted? If not then you can just hold the hand steady and turn the screen around.
Posted on Mar 17, 2011
  • eagle338
    eagle338 Mar 17, 2011
    If its an L stand you can just press the base of the stand downwards and rotate the tv. Even my LED tv has the same kind of stand so I am sure
HOW CAN I SET MY IMAGE VIEW AT ANGLES LIKE 180 DEGREES
http://www.lg.com/us/support-product/lg-PH300W#manuals The manual only shows distance to screen. There is no viewing angle adjustments.
May 23, 2016 | LG DX130 DLP Projector
How do I adjust view from an angle?
Best to have the projector 90 degrees up and down and left to right to the screen. Try turning the projector to move the image left or right.
Aug 30, 2014 | Office Equipment & Supplies
Toyota side mirror makes a clicking noise as if it is trying to adjust angle but ratchet is not engaging
It will be the drive for the ratchet is stripped and that is why the ratchet is not engaging.
Jan 25, 2014 | Toyota Corolla Cars & Trucks
Proform 980 CS treadmill - display screen is very hard to see, it's too dark. It can be viewed clearly from an extreme angle... Can the consol angle be adjusted or is there a hardware problem that...
Run the software calibration, for easy diagnose
2) However you must adjust the REED swtich, clean it, and tight every plug or connector from the machine and try again.
3) If the problem persist, the problem can be the display board. see the block diagram.
God bless you
Nov 27, 2012 | Exercise & Fitness
The headlights are angled very low to the ground. The low beams hardly do it any justice so I usually ride around with the high beams on at all times, and even then, they only project about 10 feet from...
most of adjuster remove out from the bracket in side due to more moving , so you need to re- fix inside the bracket - it;s easy look inside the head light you find the adjuster bolt with ball head is remove ,loose the adjuster first then press the bracket in the re- adjusted carefully not tight too much.good luck
Jul 09, 2011 | Audi A4 Cars & Trucks
Folding side view mirror sticking
the mirror is on a ratchet type bracket,sit in the car with the window open and adjust mirror by hand,pushing the edge that you wish to move,you will hear it click(several times),when centred it will adjust anywhich way you like.
Jul 06, 2010 | 2000 Ford Expedition
How do I adjust the seat angle to be lower on my Terry Fly Tri Gel saddle
Seat post will have an allen head screw that will loosen the fore and aft adjustment.
Sep 24, 2009 | By Terry Terry Fly Titanium Saddle Men's
Side View Electric mirror can't adjust up enough for my height
You can manually push the mirror left or righ or up and down. It just ratchets on the plastic screw adjusters. It won't do any damage.
If you have floding mirros, make sure they are locked into position.
here's what inside looks like of 2002 mirror. I don't have 2005
SECTION 501-09: Rear View Mirrors 2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
All vehicles
  1. Remove the front door trim panel (23942). For additional information, refer to Section 501-05 .
Vehicles with Mach 40 speakers
  1. If equipped, remove the speaker grille.
  1. Remove the speaker bracket.
    1. Remove the screws.
    • Disconnect the speaker electrical connector.
Vehicles with speaker delete panel
  1. Remove the speaker delete panel screw cover.
  1. Remove the speaker delete panel.
    1. Remove the panel.
All vehicles
  1. Disconnect the power exterior rear view mirror electrical connector.
  1. Position the water shield aside.
  1. Remove the power exterior rear view mirror nuts.
  1. Remove the power exterior rear view mirror.
    1. Push down on the mirror assembly to release the mirror flange.
    1. Roll the mirror assembly down and rearward.
Jan 21, 2009 | 2005 Ford Taurus
Korg Triton Keyboard touch screen fades when viewed directly overhead but is more nomal when viewed at extreme angle. This was not always the case
there is a little knob on the back of the triton to change the screen brightness. sometimes when you have had it on for a long time you will notice the screen being a little lighter, just adjust with the knob and it should fix that.
Nov 11, 2008 | Computers & Internet
Poor picture quality from 130 degree viewing angle on my LCD tv
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Apr 10, 2008 | Televison & Video
Dynex DX-L22-10A 22 in. LCD TV Logo
76 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
