Question about Sharp 25J-M100 TV
Sharp 25J M100, no remote, cant access menu. Also, how to access front input jacks since no remote
4 Suggested Answers
  • 133 Answers
SOURCE: code for universal remote
One website (Universal-Remote.Net) , says the setup code for a Sharp TV, using a Philips universal remote, is one of the following numbers: 002, 013, 014, 111, 502, 712, 812, 813, 913, 918.
Hope these numbers work for you. Please take a moment to rate this info, using the rating system below, after you have tried these numbers. Thanks.
Posted on Jul 15, 2008
SOURCE: Input jacks in Sharp 25J-M100/ Pc to Tv cable
You can purchase an s-video to composite video connector to view your Dell computer's television output on your sharp CRT television, though the image will be a bit blurry because of the connection and CRT technology limitations, though streaming video probably can be seen just fine. An example of an s-video to composite video connector can be found here: http://www.svideo.com/svideorca.html
but you probably can find a cheaper priced unit somewhere else, maybe even at radioshack.
I hope this helps!
Posted on May 29, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: We have a Sharp 25J-M100
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Posted on Jul 15, 2011
Can I hook my Roku up to the sharp 25j-m100
You can if it's a Roku 2. A Roku 3 does not have the Red/white/yellow style cable you need, but the Roku 2 does.
Sep 10, 2017 | Sharp Televison & Video
Sharp instruction manuals
Contact Sharp customer service on the web..Sharp website...give them the model number you gave us.
Sep 04, 2014 | Sharp 25J-M100 TV
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
Jul 15, 2011 | Televison & Video
Tv switches on for about 3 seconds ,then switches off
The capacitor(s) of TV power supply spoiled and need replacement. Please check it out and get replaced. The purpose of capacitor is to stabilized power supply.
Regards, vote please, Jay
Jan 20, 2011 | Sharp 25J-M100 TV
I hope this helps!
May 18, 2009 | Sharp 25J-M100 TV
How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Feb 11, 2009 | Sharp 25N-M100 25" TV
Code for universal remote
Jul 15, 2008 | Sharp 25J-M100 TV
SHARP TV - MODEL 25j m100
The RF jack is solder directly into the tuner module and as long as it did not break the circuit board inside that it connects to, it can be repaired . Takes a lot of heat though to solder the jack to the frame of the tuner. Sometimes I use 2 irons to get it hot before the plastic guts of the jack melt too bad. Also is sometimes hard to cram the jack back into its mounting hole, may need to file it out some. The makers don't solder these on they are just pressed in and crimped which is why they break off so easily. I recommend using the push on type cables to avoid this problem. Don't forget to solder the center conductor into the tuner board.
Hope Ya Fix It!
Feb 21, 2008 | Sharp 25J-M100 TV
Earphone
hi there, some tv model have the option for earphones, others don't, ty
Dec 29, 2007 | Sharp 25J-M100 TV
Menu
to acess the menu push the channel up button and the volume up button on the front panel or the channel down and the volume down.and the menu will appear.but you can get the originald remote at www.partstore.com good luck
Jan 16, 2007 | Sharp 25J-M100 TV
Televison & Video Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
