Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on the auto sensing cycle, it works fine on the handwash cycle. Just put a load on and now I have a slight burning smell and it shows error code 37...any ideas of what is going on? I am trying to get a repair man to come out. The machine is about 8 years old
    President:
  • 1,554 Answers
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Posted on Mar 17, 2011
Kenmore elite f 51 code
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
  • Sponsored Links
Prevention/Solution
  • Check around the inner washer and underneath for any lost clothes or jammed objects. This can be anything from toys to shoes.
Considerations
  • If there are no objects, your washer parts may need to be cleaned or replaced. Call Kenmore at 800-4-MY-Home to talk to a service representative and find out about replacement parts.
Types
  • Along with "F51", error codes "F1" and "F50" could mean the same thing. Check for these error codes and follow the same procedure with your washer.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz346p9Y6ro
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi I have a 1994 Ford Taurus, automatic trans. For the last couple weeks, I have been bothered by this sudden bucking & jerking the car does while I'm driving, it feels as though someone hit the...
Spark plugs last 50,000 miles,two to four years.
The oil has nothing to do with a drivability issue.
Disconnect the vacuum hoses to the EGR Valve and plug them. You will get a MIL Light or wrench on dash, ignore it and see if the problem goes away. If it does,replace the EGR Valve.
Jul 30, 2010 | 1994 Ford Taurus
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Dishlex global 500 dishwasher says ''of '' . It will not stop making weird noises. I Have had to turn it off at the wall.
Hi there.this is (over fill error).It has over filled & flooded water down into the base.It has tripped a flood switch in the base wich turns the drain pump on even though the washer is off.You can simply try tipping the washer to get the water out or you will need to disassemble the front kick panel at the bottom front to mop out the water.The switch will reset after you do this.Or wait a couple of days and the water will evaporate enough that the pumping will have stopped & the washer should work again.The booklet for your washer has water hight level settings in it.Sometimes someone leans against the washer and presses the buttons wich changes the water level to high & thats why this has probably happened in the first place.It may need setting to a lower level.
Jun 04, 2010 | Electrolux Dishwashers
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Stahling firebird
Cat converter is stopping up
Feb 16, 2009 | 1991 Pontiac Firebird
93 eagle vision error code 51
the code 51 is your automatic shutdown relay control. and the crank position sensor is on the bellhousing behind the passenger side valve cover.
Have you replaced any relays? Let me know.
Jan 04, 2009 | 1993 Eagle Vision
F 51 flashing, washer stopped
Suz, F51 is a rotor position failure code. Try unplugging the unit for 1 minute and then restart. I see a lot of this on the Oasis. You should be able to turn the basket freely by hand. If not have someone check to see if something is caught between the tub and basket. If that is ok, then someone will have to check the sensor itself. This can be a tough job for someone who hasn't done it before. You have to tip the washer back, drop the rotor and motor to get at the sensor. Sometimes just scraping the contacts on the sensor will cure this problem, sometimes the sensor has to be replaced. If it's under warranty, then I would call for service. If not, and you want to try to fix it yourself, just add me as one of your buddies and I can walk you through it. Catriver.
Feb 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
316 people viewed this question
Top Washing Machines Experts
