Question about Sony KP-57HW40 57" Rear Projection Television
Sony 52in. Rear Projection kp57hw40
When I turn the tv on it turns green for a minute and then it goes off.Can this be fixed?
  • mdixon009 Aug 02, 2008
    It blinks 5 or 6 times then goes off.
  • 10,594 Answers
Yeah, it can be fixed. Let me know when Tv goes to Off, how many times its Standby light blinks?
Posted on Aug 02, 2008
  • Shahid Electronics
    Shahid Electronics Aug 03, 2008
    5 times blinks shows "failure of White Balance", it means there is some thing wrong with Picture Tubes drive circuits. Now come to TV problem, as you said, its turns green and go to standby. It shows that Green Picture Tube is cause of problem. Please check its drive circuit like Green Drive IC, related voltages. If all found OK, Green Picture Tube (CRT) itself is defective and need to be replaced. Hope this info will help you out.
    Shahid Electronics Aug 07, 2008
    Hello again,
    Any update of your TV, or need more help / info?
On stnandbymode never start SONY KP57HW40
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Sony KP-57HW40 57" Rear Projection...
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
My KP57HW40
TRY REPLACING THE FLYBACK ON d BOARD (AROUND $70.00 FROM SONY) THIS WILL FIX THIS MOST COMMON PROBLEM ON THIS MODEL
Oct 25, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony projection tv
Sorry to be the bearer of bad news but I have the same model Sony with the same problem it was just returned from the repair shop (not to mention a $95.00 diagnosis charge) I was told that it will cost $700 to repair. The bulb in the back is gone and Sony no longer makes it so it would have to be re-built from scratch. I'm done.....
Aug 12, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Overheating problem??????
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 08, 2008 | Sony KP-57HW40 57" Rear Projection...
Green tube goes out
Dec 27, 2007 | Sony KP-57WS500 57" Rear Projection...
The screen turns red after being on for about 30 minutes
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
or
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
SONY KP57HW40 TV
Bad green CRT = common problem..........................T.
Oct 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
