Question about Iolo Technologies System Mechanic: Windows
I just bought system mechanic for the drive medic emergency rescue. problem is that it loads and first screen i can click enter to go to next screen which shows my hardisk but my mouse will not work and i cannot click on my hard disc and go to the next screen
    New Friend:
I ran into the exact same problem. After searching through the iolo website
I found a very short and buried confirmation that iolo drive medic does NOT work IF your system is 64 bit. Thank you iolo for being so upfront on the advertisemnt on your iolo System Mechanic Professional retail box. Truly professional of you guys.
Posted on Mar 07, 2013
  • Ron J Mar 07, 2013
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
Factory settings sony vgn-n31z/w
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
Oct 03, 2012 | Sony Vaio VGN-N31Z/W
Reset to factory without disk
which operating system ?
hope this helps
Sep 30, 2012 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
I want to take internal drive from one computer and install in another. Do I need to format that drive before installing?
no you dont have to format the hard drive before installing it
you would either format or delete all of the data from this drive if it has an operating system on it you would format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
Oct 16, 2011 | Computers & Internet
Format hard dirve
hope this helps you
Oct 12, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
When switched on it only displays lg logo.
No need to panic if your laptop is stuck at the loading screen because you can easily restore it to normal using the resources that came with your system. Booting issues usually result from missing or corrupt files, or incompatible software on your system. It is convenient to use tools that are part of your Windows operating system to fix loading issues. You can have your laptop back to normal with a little troubleshooting.
1.Place the Windows 7 installation disc into your CD-ROM drive. Restart your computer.
2.Press "Enter" when the "Press any key to boot from CD or DVD" message screen appears. Allow Windows to load the files.
3.Select your preferred settings from the Time and and currency format and Keyboard or input method boxes. Leave the Language box at English and click "Next" to continue.
4.Click "Repair your computer" toward the bottom of the screen at the next window. This will launch the System Recovery Options. Select the "Use recovery tools..." option, choose your operating system and then click "Next" at the next window.
5.Click "Startup Repair" at the System Recovery Options window. Allow the tool to scan your system for issues that are causing your laptop not to boot. Click "Next" to reboot your laptop. Windows should load like normal, but it may reboot several times on its own first.
I hope you find it very helpful. Thanks.
Aug 22, 2011 | Computers & Internet
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
Rescue and recovery software
Start the computer.
As the computer starts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
Specify the language settings that you want, and then click Next.
Log in as a user who has administrative credentials, and then click OK.
Click Dell Factory Image Restore.
In the Dell Factory Image Restore window, click Next.
Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
Click Next. The computer is restored to the default factory configuration.
When the restore operation is completed, click Finish to restart the computer.
Jul 02, 2010 | Lenovo ThinkPad T61 Notebook
Acer TravelMate 8200 recovery and system disks
Your hard drive has a hidden partition that contains the original factory OS and program stored for rescue and recovery.
1 Boot to Windows.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Dec 12, 2009 | Acer TravelMate 8200 Notebook
Driver loading
just click stat-- then settings--- then printer and faxes--then on left side you will see the add printer option.there you just click NEXT-- NEXT option.and you will get to select the printer from the list.the basic printers are already loaded in the windows network.you just select the proper printer model.first select brand that is HP then select modelthat is 640.if by chance 640 is not listed you select only hp desk jet.keep your printer connected to pc this will solve the problem of drivers.
Nov 29, 2007 | HP DeskJet 640c InkJet Printer
Iolo Technologies System Mechanic: Windows Logo
1,067 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Jax Planet
Jax Planet
Alun Cox
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
