Question about HTC Hero Smartphone
H,i I tried to give a hard reset my phone but pressing the key recovery and has a symbol on the screen, now does not respond, how long should I wait or should it be immediately?
  • 341 Answers
Did you press the MENU.
Follow the following steps:
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone.
Posted on Mar 17, 2011
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
Delete pasword
is cant make that cuz one way solution is hard format
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Apr 27, 2014 | Samsung Galaxy Cell Phones
How can i reset my phone with the emergency call screen,i locked myself out my phone
Apr 21, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Password
Apr 20, 2014 | Samsung Galaxy Cell Phones
My tablet model p3100 reset repeadely
Apr 16, 2014 | Samsung GALAXY TAB 2 7.0 8GB BLACK P3100,...
Notification Alerts
Apr 10, 2014 | Samsung GALAXY S4
Try to reboot but still on ftm mode
Apr 09, 2014 | Samsung GT-P6200 Galaxy Tab 7.0 Plus 16GB,...
Master reboot
Mar 24, 2014 | Samsung Galaxy Cell Phones
Samsung galaxy s2 screen not locking
try this
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Mar 07, 2014 | Samsung Galaxy S GTI9000 Smartphone
Hi My hands free symbol comes on the hole time! I did change the general settings and defaulted the hands free kit. But the symbol keeps coming back! What can I do?
Do this :
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
(Rate me pls!)
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Dec 22, 2010 | Nokia 6233 Cellular Phone
HTC Hero Smartphone Logo
80 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
