Question about Sanyo EM-S9000 Microwave Oven
How do you change from inside vent to outdoor vent through chimney; keep louver closed
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
How do i get the air vent cover off, so I can clean grease from the top.
Good Afternoon Friend,
I understand you are trying to the air vent cover off your Frigidaire microwave, model# PLMV169DC, so you are able to clean the grease from underneath the top cover. Please follow these instructions:
1. Disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the louver mounting screws.
3. Pull the louver away from the unit.
4. Change the charcoal filter.
5. Carefully push the louver back into place and replace the screws removed in step 2.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire PLMV169DC Microwave Oven
FGMV205K cover removal
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
GE spacemaker profile xl 1800 moving vent will not close
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl1800 vent fan
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Hinged exaust door on top of microwave only partially opens then repeatedly and rapidly bangs open and closed
The service manual for that model is here.
It may be a bad limit switch / detector switch in the louver circuit or there may be a bad cam in the louver.
There's a YouTube video available showing how to remove a typical over the range grille (and if necessary) control panel assembly in under 5 minutes.
Some additional info on disassembling louvered models:
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
(There are three L-shaped clips that fit into a slot to hold bottom of the vent)
Then remove one screw (which holds the control panel in place) near the top of the control panel.
Once that screw is removed the panel tilts out so you can disconnect the wires and then slip it out.
Be sure to mark and/or photograph your wires so that each one gets back exactly where it was after the repair.
Reassembly is accomplished by sliding the L-shaped keepers in place, then sliding the vent grill to the right and pushing it into place.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 30, 2013 | Samsung SMH7178STD Microwave Oven
We have a sharp 1480 and have to mount it with no outside vent. Can this be done? patqlt@verizon.net
Most of these over the range models come already set up for unvented operation. That is, set up for use with no outside vent. The oven will filter air through the a charcoal filter inside the upper grill and the vent covers underneath. If you ever wish to change the operation to allow the unit to vent outdoors, you need to change the direction of the blower fan assemby inside the top of the microwave oven. These instructions should be listed in the installation manual that comes with your oven.
Aug 16, 2010 | Sharp R-1480 Microwave Oven
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
R1610 microwave
It's called a vent louver. You'll need the exact model # from inside the microwave when inquiring to get the correct color.
Check with www.microwaveglasstrays.com or call them toll free @ 1-877-894-0035 to order. (I think they're somewhere in the $35 range.
Aug 28, 2008 | Sharp R-1610 Microwave Oven
Sanyo EM-S9000 Microwave Oven Logo
26 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
